Select , and then Appearance to tailor your navigation and projects.
You can adjust:
- Field of view
Fine-tune the view by selecting your preference on a scale from 0 (orthographic) to 90 (perspective) degrees. - Hidden edges
Turn on Show Hidden Edges to make the bodies transparent and highlight and select their edges. This is useful if you have a complex geometry and you want to see what’s “inside.” - Two-finger rotation
You can turn on 2-Finger Rotation to rotate your view without moving the position of the camera. - Curvature
You can turn on Show Zebra to show the curvature of solids and surfaces. By doing so, you can see how the surfaces meet and determine the surface continuity (G0, G1, and G2). Under Direction, you can specify whether the stripes should be horizontal or vertical.
If you're left-handed, then you can move the menus and buttons on the screen to better suit your hand’s position. In your project, go to Settings > Preferences > Interface, and switch on “Right” to move the modeling menu to the right side.
