Select , and then Appearance to tailor your navigation and projects.
You can adjust:
- Field of view
Fine-tune the view by selecting your preference on a scale from 0 (orthographic) to 90 (perspective) degrees. - Hidden edges
Turn on Show Hidden Edges to make the bodies transparent and highlight and select their edges. This is useful if you have a complex geometry and you want to see what’s “inside.” - Two-finger rotation
You can turn on 2-Finger Rotation to rotate your view without moving the position of the camera.
If you're left-handed, then you can move the menus and buttons on the screen to better suit your hand’s position. In your project, go to Settings > Preferences > Interface, and switch on “Right” to move the modeling menu to the right side.
