If you have an Apple Pencil, tap any geometry in your design. Of course, you can also select multiple geometries together.
- Tap once if you want to select a face, sketch, or edge.
- Tap twice, or long tap, if you want to select an entire body.
If you have a mouse or trackpad, click any geometry in your design. To select multiple geometries together, press the Shift key while you click the geometries. Or, you can press the Command key and A to select all items in your design space. To deselect all, press the Command key and . or simply the Escape key.
- Click once when you select a face, sketch, or edge.
- Double-click if you want to select an entire body.
Each selection you make is indicated with a blue color, and any measurement related to your selection appears at the bottom of the screen.
Once you select a sketch, closed sketch, face, body, or edge, you can modify it with different tools. Depending on what you select, a custom menu with suggested tools will appear so you can immediately adjust the selection.
To deselect the geometry, tap or click on the empty area of the grid.
From app version 3.57, the Shapr3D app will highlight anything you hover over—a face, sketch, edge, reference geometry, axis, etc.—in your design space.
