You can run the app in view-only mode on the iPad Mini (2012-2014) and iPad Air (2013). Comfortably showcase your designs in our app by importing your files.
As of now, you can use the Apple Pencil, or keyboard with mouse/trackpad to sketch and model with Shapr3D:
- If you have an Apple Pencil, then you can use the app in its full capacity on all generations of iPad Pros, iPad Air (2019 and later), iPad mini (2019), and iPad (2018 and later).
- From app version 3.54, if you have a keyboard and a bluetooth trackpad or mouse, you can use the app in its full capacity on all generations of iPad Pro, iPad Air 2 and newer, iPad mini (2015 and later), and iPad (2017 and later). For more details on compatibility of your bluetooth trackpad or mouse, check out Apple’s support article.
From app version 3.53, iOS 13.4 is required.
For the best 3D modeling experience, we recommend you use the Apple Pencil (1st or 2nd generation) because the stylus enables key functions in Shapr3D. The Apple Pencil’s pressure sensitivity outdoes the average stylus. But if you don’t have an Apple Pencil, you can use a keyboard with mouse or trackpad.
