Purchase via web
If you purchased your subscription from the Shapr3D website, you can only cancel it from the website.
- Go to shapr3d.com.
- Select Sign In.
The Login screen appears. - Enter your email address and password, and select Log in.
The Your subscriptions screen appears. - Select the three dots next to your subscription plan and then Cancel subscription.
- Select Turn off auto-renewal in the upcoming dialog.
Your subscription plan will be active until the end of its term, and your plan details will be updated with an expiration date:
Purchase via App Store
If you purchased your subscription in the App Store, you can only cancel through your iPad’s Settings app.
- Open Settings.
- Select your name at the top.
- Select Subscriptions.
If you don’t see this, then go to iTunes & App Store. Next, select your Apple ID and then View Apple ID, enter your Apple ID (sign in if required), and select Subscriptions. - Select the Shapr3D subscription you want to cancel, and then Cancel Subscription.
