ℹ️ Shapr3D’s Screenshot tool is available only to Pro users,
but all users can take screenshots of the augmented reality view.
You can capture a screenshot of your iPad to save an image of your design, but that’s not ideal when you want to present your design in a professional way. You’ll still see the grid, edges, and UI elements.
Instead, you can export your design as an image with Shapr3D’s Screenshot tool, so you can showcase your work with a polished look and a transparent background. Or, you can take a screenshot of a real-time visualization of your solid and mesh bodies—displayed via augmented reality (AR).
Screenshot tool
You can use the Screenshot tool in five steps:
- Open your design in Shapr3D.
- Select the Share button in the Top bar.
- Select Image in Usage.
- Customize how you want your exported image to look.
: Render your design with or without edges.
: Remove or keep the grid in the background.
: Make the background transparent or filled.
: Choose which items to display.
- Select the Shutter button to capture the screen. The exported image will automatically save to your Photos app.
Screenshot of AR view
- Select Augmented Reality in Usage.
- Select Preview 3D Model.
- Aim your iPad’s camera to a setting in which you want to visualize your model.
