Shapr3D supports the following file formats which are compatible with most major CAD software, and Apple’s AR ecosystem:
- 2D
- DWG
- DXF
- 3D
- X_T
- STEP
- IGES
- OBJ (with colors)
- STL
- SHAPR (the native file format of Shapr3D)
- USDZ
Use SHAPR to transfer models between different Shapr3D apps and projects.
⚠️ If you use the free version of Shapr3D, you can only export in low-quality STL.
