Electric engine
Master advanced modeling techniques in this series on electric motor design.
5:06
Episode 1 | Main sketch
Learn how to create the main sketch. The sketch will be a revolved sketch for the motor frame and end caps.
3:09
Episode 2 | Revolving
Now that the sketch is complete, learn how to revolve each of the 3 sketches to generate 3 unique bodies.
5:34
Episode 3 | Hubs
Learn how to sketch the hub design that will be used to bolt the end caps to the main frame.
4:33
Episode 4 | Creating the fins
Learn how to sketch the fin, extrude it, and copy it to generate all fins around the main frame.
5:46
Episode 5 | Creating the legs
Learn how to create and mirror the legs of the electric motor.
2:47
Episode 6 | Terminal box
Learn how to use the Replace Face tool when trying to extrude a sketch up until the revolving surface.
3:33
Episode 7 | Terminal cap
Learn how to create the terminal cap and the difference between using push to extrude and the standard Extrude tool.
2:06
Episode 8 | Section views
Learn about section views and how they can be used within Shapr3D.
3:18
Episode 9 | Main shaft
Learn how to create the main shaft and transform it into the motor frame.
4:53
Episode 10 | Screws
Learn to create the screws, insert them into the motor, and make copies using Transform/Translate.
1:26
Episode 11 | Union to combine the frame
Learn how to use the Union command to combine bodies.
4:46
Episode 12 | C Hook mount
Learn how to create the C hook mounts.
3:29
Episode 13 | C Hook
Create the C hook using Sweep and use the Translate tool to translate it into the C hook mount.
4:13
Episode 14 | Mirror the front cap
Learn how to mirror the front cap and bolts to create the back cap.
4:05
Episode 15 | Fan pattern
Learn how to sketch out a complex sketch using Copy and cut away the fan pattern on the end cap.
6:07
Episode 16 | Fitting screws
Add final touches to this electric motor design and add the remaining bolts to the finished design.
