Adding indents and fillets: Motorcycle Gas Tank | Shapr3D Basics
80% of your CAD work is generally edits. Learn how to quickly edit shapes, adding indents and fillets using Shapr3D’s Selection-Based Interface (SBI) to your motorcycle gas tank. With SBI, you preselect items, then pick from a list of appropriate features, replacing the time you would spend searching through menus with more focused design work.
0 out of 0 found this helpful
