Measure precise volume: Motorcycle Gas Tank | Shapr3D Basics
Learn the process for calculating volume of a select body. You walkthrough creating a new body from a rectangle placed around the motorcycle gas tank, using the Subtract tool, and working with Design History to keep tool bodies and then calculate the volume of the tank.
0 out of 0 found this helpful
