Setting up Primary and Secondary Fillets with Design History: Motorcycle Gas Tank | Shapr3D Basics
Set up secondary fillets to flow around the primary fillets, easily reordering Design History features to create the right shape and working with Hidden Edges to adjust any edges. You also get troubleshooting tips for when you run into an error crafting your model so you can adjust and keep modeling smoothly.
0 out of 0 found this helpful
