Import models: Assembling a motorcycle engine
Leverage Shapr3D’s all-around compatibility to import parts and explore bottom-up design creating this motorcycle engine. You can quickly align and edit parts, including an imported block casting, crank, and piston rod using Shapr3D’s Selection-Based Modeling Interface to get a smooth process making them fit together.
1 out of 1 found this helpful
