Lampshade outer tool surface guide | Shapr3D Design for Manufacturing
Start constructing the outer tool to trim the vacuum-formed part by sketching a surface guide on of flat faces on top of half of the shade to mirror later on. You’ll use a cross-section of the lampshade leaf and project onto a parallel plane to sketch out features for the tool. This will create flat faces to use to trim away the inner surface of the component.
0 out of 0 found this helpful
