Lamp arm exterior template | Shapr3D Design for Manufacturing
Make a template to carve out the outside shape of the lamp. You’ll extend the interior template sketch framework using parallel construction lines and offsetting them to create a basis for the outer template. Customize the offset to fit your router bit’s bearing lines and length.
0 out of 0 found this helpful
