Template for trimming inner pockets and groove | Shapr3D Design for Manufacturing
Cut out a guide in the exterior template to create the groove and hole details in the lamp arm and trim the outer edges including cavities. You’ll build a construction axis, extruding the grooves and holes while excluding bodies in design history, and using subtract and union to create the framework for clamping pieces together and trimming the outer body surface.
0 out of 0 found this helpful
