Soap Bottle Design with Revolve, Shell, and Split Body
Get step-by-step instructions on creating this organically sculpted soap bottle body, adding threading, and prototyping a mechanical cap. You’ll focus on key modeling tools including Revolve and Splines along with using design history to find the right shape and prototype various stages of elements. Finally, add a product presentation for material studies, leveraging real-time editing capabilities to quickly finalize your model’s look.
Hello everybody and welcome to this tutorial in which I'm going to show you how easy it is to sculpt such a nice looking organic soap bottle in Shapr3D. Topics we will take a look
00:13
at is all the necessary sketches we have to only create. And then how by using the history
00:21
line, step-by-step, we are going to create the building blocks of our design. And then...
00:30
Use these very basic building blocks and start adding all the details, for example, edge roundings,
00:37
inside shelling and fillets. Build the piece outside, create then a functional cap. And
00:45
even, for example, use the ability to resume and suppress features to prototype various
00:55
stages of how elements could be rotated and manipulated. And then we will finish with a
01:03
really nice looking product presentation, adding some colors to the background and materials
01:10
for an adequate color material studies. And with all that said, let's do it. So here we
01:18
are inside a new and empty design. The first thing we want to do is make sure all our snap
01:25
options are turned on. and also our unit system is set to millimeter. A bottle is a revolve
01:33
body. So the easiest way to start is by going to the front and creating the front profile
01:40
to revolve. I moved the screen down a little bit. Go to Sketch and we will start with the
01:47
Line tool. At the center of the sketch where Z and X meet, and draw a line to the left side.
01:54
Select the first point that is the center of my bottle and hit the lock icon. Because this
02:02
point, I never want to move. This line, I will dimension to 30 millimeters, select the line
02:10
and also constrain it to be horizontally aligned. I can zoom out a little bit. Then I draw a
02:17
line straight up. This line will be 100. 50 millimeters and vertically constrained, zoom
02:24
out a little bit more. And then on top, I can draw a line to the left side. Make sure this
02:32
is horizontally constrained. And this is 15 millimeters. This is, for example, the top
02:42
diameter and 30 is the bottom diameter. And the 150 is the height of the body. Since we
02:49
have the line tool active, we can zoom in to the top and put in the preliminary geometry
02:56
for the cap. This will be 40 millimeters up, horizontally constraint. Then I can go to the
03:06
right side and go down and make sure that these two lines are horizontally, vertically constraint.
03:14
So now as you can see, I have 150. and I have 40 millimeters. To show the dimensions all
03:23
the time, we can turn on, always show the dimension,
03:29
also always show the constraints, or leave this off. And then when we select a line, we see everything that is important. We can now
03:41
go ahead and create the spline to sculpt the shape of our bottle. Go to the spline icon,
03:50
double tap it, and then you have the option between the control and the fit point. We're
03:55
going to use the control one. So what I will do is from the top, I start drawing and then
04:02
press, go down, press, go to the center and inwards, press, go down, outwards, press, go
04:09
down, press, go to the end and release. And you see this creates a really beautiful shape.
04:19
What I can do now is play with the distance of how far these points are apart from each
04:25
other. So here I will make this a little bit smoother by bringing these points down. So
04:34
they all have exactly a similar distance to each other. On top, I would like to have a
04:40
sharper corner. and also a nice and long part on the curve. So there you see the distance
04:48
is actually much longer between these two points, then these two points.
04:56
And then with this one here in the center, I can play with how much this belly's in. And
05:05
that, for example, is in the space where the fingers kind of like go around the bottle.
05:11
At this point, we kind of like have everything to make a quick prototype. So we'll select
05:18
in the sketch profile of the bottle, then select a vertical line or the Z axis and click Revolve.
05:29
This hides the sketch. So we can show the sketch one more time. And then select the sketch profile
05:38
again. Select an axis and revolve. What is really nice is we can then go ahead and select the
05:55
sketch. Go into Sketch Edit mode, select nothing. And then when we select individual points,
06:02
we can move them around and see how this does update. the shape of our bottle on the fly.
06:11
That's actually really beautiful. Even while history-wise, the sketch is created in front,
06:22
so before the revolve bodies, we can edit steps at the beginning and see how this influences
06:30
the rest of the construction in real time. This is super amazing.
06:39
This bottle is very round and all I want is from the front to see this nice curvature look,
06:45
but actually from the side should be more flat. So I need another sketch. We'll go to the bottom.
06:55
Then I will go to Sketch. And you see, actually,
07:00
when I do this, I have all these sketch intersections to prevent, for example, any... Accidental snapping,
07:08
I can turn everything off and then actually create the circle. So I don't snap to a piece of a sketch or geometry where they intersect.
07:22
Change my view, rotate, exit the sketch. Then I can show everything. And you see that the
07:28
sketch also sits actually directly at the bottom of the bottle. So... and just select the sketch
07:36
and you see where it intersects with the bottle. This is a new profile to select. And that's
07:46
not really what I want. So what I will do is I will select the sketch, exit it, and then
07:52
simply move this down a little bit. How much is up to you. Beautiful. You see now I have
07:59
just one sketch profile. So. Let's select a sketch. Going back to the bottom view. And
08:10
with the spline command, I can now go ahead and draw myself a nice curve.
08:23
And there, beautiful.
08:28
When these two splines are not... connected via a symmetry constraint. I can model every
08:37
spline basically independently. And if I would like the front and the back spline, kind of
08:47
like function, like a mirror, then I have to create a Y and an X symmetry. So let me show
08:54
you how we can do this. This is very easy. So I will select the Line tool along the Y axis,
09:00
I make a line, and along the X axis, I make a line. I select both lines and lock them so
09:06
they don't move. Now select nothing. Then I select two pairs of points, symmetry and the
09:15
X axis, the opposite symmetry axis and the center points and this axis line. When I now select
09:27
one point, you see the opposite moves. But you see here, when I go left and right, the right
09:37
point doesn't move. So this is actually now where we will select the left and right points,
09:45
symmetry, and then we log this to the other line. And then when we go ahead and move these
09:52
corner points, There we are. Now I can go ahead and for example, move this one up, move this one down or stretch this
10:04
out. And by this, essentially with this line can project how I'm going to slice the bottle.
10:14
So let's do this. We will exit the sketch, select nothing, select the sketch profile. And then
10:22
hit the up arrow, Extrude, and then we cut through the bottle. Obviously, I don't want to remove
10:30
the bottle. I want to remove the outside. So by clicking on this tiny icon with the white
10:39
sphere and the blue cube, I can then get into the... Boolean command and decide to add a
10:47
union, new body, subtract. And actually I would like to use the intersect command. And that
10:54
basically gives me the volume of how these three objects, so the cap, the bottle and the thing
11:01
I extruded intersect. Beautiful. Again, one little tiny demo. When I go back to... editing
11:13
my sketches, I see everything in real time. It's actually really nice how this works. And
11:23
the same is also true for this one here. I don't have to go even into a 2D view. I can prototype
11:33
this by selecting the sketch, going to Sketch Edit, and then I use the grid for the movement.
11:43
Perfect. So this looks pretty good. So we have the main bottle and the cap, but we don't really
11:55
have the neck that goes onto the bottle. And this is where I will go ahead and then select
12:04
the first sketch we created and edit it and create two more lines that go inside. One line.
12:13
to here, this should be 11 millimeters and horizontally
12:19
constrained. And then one line straight down, vertically constrained. And this line should be 30 millimeters.
12:34
When I now open the history, you see, I have my first sketch, my two revolutions, my second
12:40
sketch, the extrusion. And when I click on the first revolution, there I see that this is
12:47
actually the feature that created the main bottle. I click on the arrow on the right side to expand
12:56
it. Here I have Profile and Axis. Click on Edit for Profile, and then I will add this sketch
13:05
profile I just created to it. Click Done. And I have updated my design. That's how easy you
13:13
can create different iterations. And you start with very basic models. And then step by step,
13:21
we create more refined complex models. So let's actually refine this bottle. I will turn all
13:33
the sketches off. So I only see this bottle and I can pay attention to how... these edges
13:42
all meet. There are various different ways how we can fillet them and round them. We want
13:49
also later to shell the inside. So before we do our shelling, we want to round all the sharp
13:56
edges on the outside, because then the shelling command does the work of the inside, because
14:03
the rounded edges will shrink down to the inside. And we'll see this in a moment.
14:12
When I select this edge, just as a demo, just don't follow it, just take a look. You see
14:18
how I can round this vertical edge. Then I get these nice rounded corners, edges, and then
14:28
I can round this a second time. And then what you see is we get this connection where we
14:36
have kind of like... two profiles which are rounded, and then this centerpiece. We have
14:44
here very sharp corners. That's not really very nicely looking. So I undo everything. We can
14:52
actually select all edges at the same time. There we are. And then we drag the arrow to
15:04
round this. and pay attention to how this looks. This is nice. And then we click the clock icon
15:13
and switch the corners from Rolling Ball to Setback. Takes a moment to calculate and take
15:22
a look at these beautiful corners. They look actually really great.
15:33
We want to adjust... the radius of the fillet, we can go to History, look where the fillet
15:38
comment is, click on the arrow to expand it, and then change the radius. There we are. It's
15:48
very easy.
15:55
We could also select a face of that fillet. And there you see it says, Edit Fillet. When
16:02
we click on this, Then there we go back to the original command and here we can change that
16:09
value. So same thing. So this is actually done. That's good. This corner we can keep sharp.
16:19
That is fine. This one I would like to round a little bit, one millimeter. This looks sufficient.
16:25
And now actually the bottle is ready to be shelled. So I can select that top face. Go to Shell
16:35
and I will select 2mm, which is a little bit thicker. I do this on purpose because it's
16:42
an easier surface to see. If I go to the front view and then at the bottom left, select Section
16:51
View, we can take a look into that space. There we can see how we have also inside all the
16:59
edges. See, that's the reason why we... fillet the edges first, and then we do the shelling,
17:07
because it does create this for us in the inside with a perfect material thickness. I have here
17:16
a very sharp edge. If I would like to round this, I could also round this fillet, actually,
17:23
sorry, this edge, say by one millimeter. Let me show you something. If I go to the history
17:30
view, Here's my shelling command. Here is that fillet command. And if I press onto it, hold,
17:39
I can drag this in front of the shelling. And there everything is updated. This is a pretty
17:49
big fillet. Change this a little bit. You see everything updates for us automatically.
18:03
We can zoom out a little bit and then go to turning off the section view. And there we
18:12
are. So we have now actually the main bottle and the neck done. We don't have the threading.
18:21
The threading is something we can do actually later. It's a complicated task and this actually
18:26
only makes sense when also the cap is done. So let's go ahead and prototype the cap a little
18:32
bit. I will go to Items. Sketch 1 was the first one we created that has the basic dimension
18:43
for the cap. Currently, the cap is only a cylinder. We would like to change this, obviously, now.
18:50
So then let's go ahead and edit this cap. I
18:57
would like to have a wall thickness of 2 millimeters for this cap. And the cap actually has a lid on top that can swivel. So I need to define
19:07
now a vertical line here. So I draw one line down. I will actually also hide the geometry.
19:16
So this is easier to work. You see, I drag the end points onto the edges. Make sure this is...
19:27
vertically constrained. Then I can select these two lines and make sure this is 2 millimeters.
19:35
That's good. We have a swivel. So here's the horizontal line, and this should be around
19:49
4 millimeters. Now, when this cap rotates, onto the neck. It should kind of like seal it a
20:01
little bit. So I would like to have here a very thin horizontal kind of like cab or lid that
20:11
goes over it. And then we cut a hole into it for the fluid to come out. And I need one additional
20:19
horizontal line. And one millimeter. So if I... Zoom out a little bit and only select the elements
20:29
for the cap, main body. That's this. This is actually the space where the threading goes
20:38
in. This is a cavity. And then this is actually the part of the swivel, kind of like the button
20:46
that can rotate to open and close. And as before, We can go to the history. In this case, it is Revolution 2. There we are.
21:01
Open this, go to Edit Profiles. And now I deselect everything and then just select only what I
21:12
want. That is it. Click OK. There we are. Look, we have actually updated that geometry. So
21:22
you see, we don't really create... basic geometry and then make new ones. We actually build basic
21:29
geometry and then we can start adding more elements to it. We can close this a little bit. There
21:38
we are. We can then select this upper sketch profile and select this line and do a revolve.
21:50
That for example, is actually the part that can rotate. Just with a finger press, we move
22:00
one side down, and then the other side goes up. So the interesting element now will be
22:12
to prototype the mechanics. So this is a cylinder that sits inside an open cylinder. To rotate,
22:23
This is not necessarily going to work this well. We might maybe need to change the thickness
22:31
a little bit, or we can also round this a little bit.
22:41
This is actually going to be the rotation axis. So that dictates that from the front, when
22:50
we go back to the sketch, turn off the section cut,
22:58
right here between these two points, this straight line needs to be changed a little bit. Kind
23:04
of like it needs to be a little bit round. So we can do this very easy by turning everything
23:11
off, so it's easier to see. Then I will go to the Line Arc command and create here an arc.
23:23
And then this point, I simply drag over to this axis because that is the revolve axis. And
23:36
this tiny extra profile I created. This one, I need to add to the rotatable part for the
23:49
revolve and also remove from the housing. So you can go ahead. Here we have two movement
24:01
commands. I can press and hold and say, delete. I don't need those. And there is this Revolve
24:12
command. I can go to Profile and then I will add this one simply to it. And then from here,
24:26
I would like this tiny element to be removed. Go Edit. And... There, click on it, it will deselect everything
24:40
there. Just select this one then, and there we are.
24:50
And there you can see, we have kind of like that space for it. Really good. Beautiful.
25:03
Now there will be actually in the front an opening and also in the inside, we will shell out and
25:10
for the rotation left and right, we do need some sort of kind of like a sphere or something,
25:17
kind of like a joint. We use a sphere that's very easy to do because we added to it. And
25:25
then we can press this cap into the housing. So we can go back to our first sketch. There
25:37
we are. And I can see where this one is. And I will add this on the other side. Now you
25:49
have to be careful how much material I have, so like 2 millimeters. And I will draw a circle
25:58
roughly here. This might be height wise. Select the center point, and then I can move this out a little
26:09
bit. There we are. And then here I draw a line straight up and straight down. Make sure these
26:17
lines are horizontally, vertically constrained, 3 millimeters. That is good. And I will now
26:26
hide this body and select the sketch profile. Select the axis and hit Revolve. Now I have
26:36
actually one, kind of like one joint. This element,
26:42
I would like to mirror over to the other side. So I select the three dots, expand the menu, select Mirror, keep originals on, and select
26:53
this mirror plane. Then,
27:00
I can now show all three bodies, so the two spheres and also the cap and join them together.
27:15
I move the sketches closer to each other, so it's easier to select them all.
27:23
The inside, at this point, now we can shell out. I will do this with a 1.5 millimeter.
27:33
That's a little bit easier also to see. A more realistic value, for example, would be 1 millimeter.
27:42
And then we have these holes here, the leftovers of that shell and command. Not a big deal.
27:48
Simply select them and then we press Delete. And then that clean setup. Now, because we
27:55
added the spheres to the cap, We don't have that yet inside our housing. It's not a big
28:04
deal. We can simply remove it. So from this one, so from the housing, I would like to remove
28:14
the cap. Select Subtract. So you see I double clicked actually both bodies and then the Keep
28:22
Originals, we want to keep the removed body.
28:29
We can actually rename these parts, for example, so it makes more sense and it's easier to find.
28:36
It's a suggestion I can give you. And now there you can see how we have actually these openings.
28:42
Now, because these are spheres, you can all see it. It's going to be very easy to just simply force press that into it. Beautiful.
28:53
So we're making good progress. The next step is we can prototype how we can rotate the part
29:00
and then where the opening is. So let's see how much we even can rotate this one. When
29:07
we double click this, and because this is actually just four millimeters, the center of rotation
29:15
is right at the center there.
29:23
which means I can rotate this. So this is 15 millimeters. That's actually the max 10, 12,
29:31
no, 10 millimeters, 12 millimeters, sorry, degrees of rotation. That will work actually pretty
29:40
well. Go to the side view, select nothing, section cut. Now we can see how nicely this seals.
29:56
So 10 millimeters, sorry, degrees. Go to the History, we have no movement command because
30:04
I hit the handle button. What I will do now is I would like to take this surface and shave
30:13
off the back area at 10 degrees. Section view off. How do we do this? Super easy. Let's just
30:27
create a new add plane. You see, I have the top face selected and I just create this plane.
30:36
Don't move it, select the plane. And then I just rotate this one by 10 degrees. And with
30:43
this plane, I can actually now double select the housing cylinder. Select the plane, select
30:52
Split Body, click OK. And then this piece, which we split, I remove. There we are. This plane,
31:03
I will drag down in height. We don't really need this anymore to see, but we can understand
31:10
now when we rotate this 10 degrees, how this perfectly lines up. And because it's... the
31:17
housing is only cut at 10 degrees, I can't press kind of like the button more in. There goes
31:25
a lot more engineering into such a simple cap. I'm just simplifying the design here a little
31:33
bit. Let's undo the movement command, because I don't want this to be the timeline. So, since
31:44
we're working on
31:51
the housing here. Let's go ahead and detail this a little bit. We can give this a nice
31:59
fillet, 20 millimeters. So it's nice and big. That is good. And also here we can add a hole.
32:10
The opening will be where I'm kind of like pressing my finger. So, When I go to Select Sketch,
32:19
we're creating a sketch right onto that plane. There's a cylinder and somewhere here, I can
32:27
create a 4mm cylinder and cut through. Now this is kind of like the opening through which then
32:37
the soap will flow out. I go to a side view, select nothing, go to Section Cut, show the
32:44
bottle and there I see... Nearly there where it should be. I just need to move this a little
32:50
bit over. Not a big deal. We go to Sketch 3, select it, then we're in Edit mode, select
33:00
nothing, just select the point, and then we can drag this along the grid to the left. And
33:09
we see the update of the parametric model in real time. This is actually really nice.
33:19
This can go down. And besides the missing threading, this model right now is done. So let's take a look at
33:30
the cap. How do we do the opening? We can go to the front view, turn off section cut. Then
33:39
we make a new sketch. Actually turning section cut on now is very helpful because we see where
33:46
the top area is. And go to rectangle, tap twice, select from center. And then from along from
33:56
the Z axis, I make here rectangle 5 millimeters, horizontally, 2 millimeters up, double tap,
34:08
horizontal, vertically constraint. And then I can move this one up. Ideally, right under
34:16
the top surface. There we are. Section cut off, exit sketch, select the sketch profile, and
34:26
then we just extrude and cut through. We have
34:32
very sharp corners that doesn't look very appealing. If we would like to round this, that's very easy to do. And we just select these corners.
34:41
and round them a little bit. 0.5.
34:52
So if we show the other element, so the housing for the cap, and then double tap our element,
35:03
rotate it, and there we can see how this actually can come out. What about 12 millimeters? And
35:16
what about 13 degrees? I mean, not millimeters. Sorry for this. This actually looks pretty
35:25
good. Now this one does not really match. Again,
35:31
easy fix. We go to our history. Here's my construction
35:37
plane. There's my rotation. This was 10 degrees. And we just add three more to it. Need to figure
35:51
out the direction. So I inverted the value from positive to negative, and there now, this is
35:57
perfectly matched.
36:04
And this movement rotation command, And I hold onto it, I can suppress, then basically it's
36:09
turned off and I can unsuppress and then show it. So I don't have to all the time rotate
36:16
the slit element forward and backwards. I can simply turn on off the rotation command. In
36:26
terms of modeling, we're actually now at the stage where we can take a look at the threading.
36:36
I will create a new sketch. What is really nice is because we make a new sketch that cuts right
36:44
through this body, you see all the intersection lines and points. For example, here, there's
36:52
one and there's one. I'm drawing these lines down. And then for the moment, I'm turning
37:02
all the bodies off, so it's easier to see. Zoom in, the distance is 2mm. So I draw a horizontal
37:15
line, horizontally constraint, then a line diagonally down at a height of 2mm.
37:28
And that is the wrong direction. This one I will bring down a little bit. So you see, I'm
37:35
prototyping my threading. So this is the threading that goes onto the bottleneck. And this is
37:44
then the contact surface where it will touch with the threading of the cap. And that is
37:51
going to be there. Also two millimeters. And then I can move this whole thing up and down
38:00
to be nice and clean. We can specify this to be at 2 millimeters. There we are. So let's
38:08
make the threading for the bottleneck. Select the triangular sketch profile, select the axis,
38:16
and then we go Revolve. I'm still in section view, so turn this off. And here comes the
38:22
fun part. I'm just rotating this down. for example,
38:29
by 4. So I have a nice distance, but it's only
38:34
one turn. 360 degrees multiplied by 2 is 720. We get an error because then it would intersect.
38:46
So let's go 8 millimeters down, 720. There we are. That looks actually really nice.
38:59
Turn this sketch on again. Then we select the opposite profile, select the revolve axis,
39:06
revolve, bring this down also here by 8, 720. And there we see how this perfectly lines up.
39:23
So This is actually the threading for the bottle. Here's my bottle. I will select these two sketches
39:32
and bring them down a little bit. I can actually clean this up now and drag everything onto
39:40
one element. So it puts everything into a folder. And the start and end of this threading is
39:48
a little bit brutal. It's an easy way to fix this. Well, we can select one cap face, then
39:59
select a vertical edge, and then we simply rotate that face 50 degrees. We can do the same with
40:10
the other one. There we are. Now that already looks much, much better. Here would actually then be this inside
40:23
edge, and this goes in by 50 degrees. And here, this one to there. Beautiful. And these rotations
40:37
I did are also registered as rotation around axis features and can be adjusted. afterwards
40:45
all the time. So the reason why I actually created this is now I can select these upper edges
40:55
and very nicely round those. So there's a much better looking fillet. And then the threading
41:05
has a really nice start. I might want to do the same also. or the other edges. So I can
41:17
go to History, activate the Fillet, go Edit, and then rotate my view and add the other edges
41:32
of the other threading. Click Done. This makes really a lot of sense to work nice and clean
41:38
and group your command. There we are.
41:46
So that's ready. We will join to the bottle by simply double tapping each body, and then
41:54
select Union. And then we do
42:02
the same with the housing for the cap, Union, and there.
42:15
So there we are now. To bring everything to an end, we can add nice fillets to our specific
42:30
edges we can select. For example, all those and round those a little bit.
42:40
You have to be careful that the value you were selecting is good. There was actually a small
42:49
collide properly up here. This is nice and good. These tiny fillets are actually really nice
42:56
because they make everything look nice and soft. And also when we create visualizations, they
43:09
create very nice separations between the body parts because they create like highlights and
43:14
shadows. And simply you see where pieces are put together or not. Let's unsuppress this
43:22
one. This looks very good. So everything is now ready to go into the visualization mode.
43:28
So I go to Modeling, select Visualization. There we are. And we can now decide what... type
43:36
of material here we would like to use. We have glossy ABS, we have a matte ABS. Can drag the
43:48
matte ABS on the main body, and then the glossy onto the top. Then the glossy, I also put onto
44:00
the rotation element. You see the other material was then removed. That's a red bottle. Let's
44:08
streamline this a little bit. So the matte material, I would like to be instead of red, simply white.
44:14
So tapping onto it gives me then the ability to select a white material. And then the glossy
44:24
one, since this is going to be for a bathroom application, I give this a nice kind of like
44:31
a nice mint color. So, There we are. So we can just pick something here, there. Beautiful.
44:42
This looks good. And the white body does not separate really well from the background. That's
44:51
a very easy fix. We just go to Environment. Here we have various options of... and default
44:58
background, transparent background, a colored background. And because this is a colored background,
45:04
we can click on the cog. And then also here, for example, give this different materials.
45:12
And now you see based on how we work on, do we make actually the cap pop more? Do we make
45:20
the background pop more? We just play with the color contrast. There we are. Then We have
45:27
the ability with the rotation for the light to specify where the shadow is and also where
45:35
the highlight is. If the material for the cap, for example, is way too glossy, it's a very
45:43
easy fix. So we look down, we have, for example, the PVC or melamine. We can simply select the
45:54
glossy material. And at the bottom, we changed the color of the material, but on top you see
46:01
it says to the right of ABS, Change, select it, and then we can swap this out and select
46:10
different types of materials. This actually works really, really well. That's how easy
46:20
you can do very quickly a nice CMF study of your product. and then theme everything based
46:28
on the material, and then also the color. And then to create a nice rendering or photo of
46:34
this, all we have to do is click Capture. And that is everything. In this video, I hope you
46:41
saw how easy it is to create such an organically sculpted body, and then also how easy it is
46:46
to create the threading and prototype a mechanical cap. Have a good day.
Soap bottle
6 out of 7 found this helpful
