New features
Polygons
We are introducing Polygons: they won't be separate lines anymore. This will help you with editing and moving polygons with a higher level of control:
- Select a line, and use the arrows to change the radius - all lines will update accordingly
- If you want to handle the lines separately, disconnect them
Improvements
- Tweaked Apple Pencil Pressure sensitivity in Settings - clear info, bigger distinction between options
- Left/right-handed interface configuration is now only available in Settings (swipe gesture has been removed)
- Updated Tool icons
