When you select geometries in your 3D design, Shapr3D instantly predicts the tools you can use to transform your selections and tailors the menu according to your needs. You don’t have to search for the right tool from the main menu anymore; the right tools immediately appear in front of you.
Take a look: The adaptive menu includes the Revolve tool, so you can quickly create a 3D body.
You can easily switch gears and adjust the body with other tools such as Rotate around axis and Shell.
See how you can make use of the new adaptive UI in our updated tutorials: shapr3d://tutorials.
