⚠️ Only Pro users can use the import feature and this workaround.
Currently, Shapr3D does not support direct input of text in the design space. However, there are a few workarounds.
Method 1
- Draw the text with iPad-compatible drawing apps such as Concepts and Procreate.
- Export the text in 2D DWG or DXF file format.
- Import the file into your active design in Shapr3D. For more details, hop over to this article.
The text will be shown as sketches. - Place the text onto your models with the Project tool.
Method 2
- Download this SHAPR file that contains alphabet sketches.
- Use the Project tool to project the alphabets onto your model.
