In the Designs screen, all your work in Shapr3D is displayed.
You can permanently delete designs in a couple steps:
- Select Edit in the Designs screen's top right corner.
- Select the designs that you want to remove.
If you accidentally select a design you want to keep, just select again to deselect
- Select Delete.
This dialog appears. - Select Delete again to confirm the deletion.
