After you create your designs, you can always rename them in the Designs screen.
If you're using your iPad's virtual keyboard or a physical keyboard, select the design name and start typing to rename the design. When you're done, press the Return key.
If you're using iPadOS 14 with an Apple Pencil, you can handwrite with your Apple Pencil the design name in the name field.
