Here’s a cheat sheet that’ll show you shortcuts and basic gestures for the mouse and trackpad. If you're using a mouse, make sure secondary click (right-click) is enabled. If you're using a trackpad and you prefer to tap, not press down, you can register taps as clicks.
Navigation
Rotate camera |
Hold down the Shift key and pan with two fingers on the trackpad
Move camera |
Pan with two fingers on the trackpad |
Zoom camera |
Pinch in or out with two fingers on the trackpad
Zoom to face |
Hover over a face and press the Space bar |
Reset view | ⌘ 1 | |||
Rotate 2D view by 90 degrees
Click the right or left arrow above the Orientation Cube | |||
Switch to front view | ⌘ 2 | |||
Switch to back view | ⌘ 3 | |||
Switch to top view | ⌘ 4 |
Switch to bottom view |
⌘ 5 | |||
Switch to right view | ⌘ 6 | |||
Switch to left view | ⌘ 7 |
Selection
Select single part | Click the part | |||
Select full object | Double-click the object | |||
Select multiple parts |
Hold down the Shift key and click each part |
Select area |
Click anywhere in the design space and drag to the right or left |
Select all |
⌘ A | |||
Deselect all |
esc | |||
Cycle through selection filters |
Filter selection for bodies only |
B | |||
Filter selection for edges only |
E | |||
Filter selection for faces only |
F | |||
Delete | ⌫ |
Sketching
Before you can use the following, first click Sketch in the main menu.
Start sketch | Click anywhere in the design space | |||
Finish sketch |
Finish sketch and remove last-placed point |
Add fit point to spline | Long-click anywhere on the spline |
2D drawings
Update 2D drawing | ⌘ R |
Other
Undo | ⌘ Z | |||
Redo | ⇧ ⌘ Z | |||
Execute last command | Left arrow key | |||
Search for commands |
*Images are from Apple
