ℹ️ You can also create dimensioned 2D drawings.
Every sketch, face, and body you create is precisely built in Shapr3D. If you want to see exact measurements of an object, select it and look at the bottom of your screen.
Note that if you select a body, the body's name from the Sidebar's Items manager will appear.
Depending on the type of object you select, you can see these quantitative data:
Icon | Description |
Length of a line. If you select multiple lines, the sum is shown. |
Area of a face.
If you select multiple faces, the sum is shown. |
The volume of a body.
If you select multiple bodies, the sum is shown. |
The radius of an arc, circle, sphere, cone, or cylinder. |
The diameter of an arc, circle, sphere, cone, or cylinder. |
The angle between any two lines or two faces. If you select an arc, its central angle is shown. |
A perpendicular angle between two lines or two faces. |
The shortest distance between two lines, arcs, circles, non-parallel faces, or bodies. It can also be the shortest distance between any combination of two of the following: circle, arc, line, face, or body. |
The maximum distance between a line and an arc or a circle. |
The central distance between a center point or central axis and any of the following: line, arc, circle, parallel face, or body. Center points are calculated in the case of circles, cones, and spheres. In case of bodies, the distance from the center of gravity is calculated. |
The distance between two parallel items such as sketches, edges, and faces. Note that it is possible to calculate the distance between an edge and a parallel face. This also shows the radial difference of concentric arc, circles, sphere, and cylinders. |
The distance on the X-axis between two lines, arcs, circles, non-parallel faces, or bodies. It can also be the distance between a combination of two of the following: circle, arc, line, face, and body. |
The distance on the Y-axis between two lines, arcs, circles, non-parallel faces, or bodies. It can also be the distance between a combination of two of the following: circle, arc, line, face, and body. |
The distance on the Z-axis between two lines, arcs, circles, non-parallel faces, or bodies. It can also be the distance between a combination of two of the following: circle, arc, line, face, and body. |
