Select View in the menu bar to tailor your navigation and projects.
You can adjust:
- Field of view
Fine-tune the view by selecting your preference on a scale from 0 (orthographic) to 90 (perspective) degrees. - Hidden edges
Enable Show Hidden Edges to make the bodies transparent and highlight and select their edges. This is useful if you have a complex geometry and you want to see what’s “inside.” - Curvature
You can turn on Show Zebra to show the curvature of solids and surfaces. By doing so, you can see how the surfaces meet and determine the surface continuity (G0, G1, and G2).In the menu bar or the design space, you can specify whether the stripes should be horizontal or vertical.
