You can use the Mirror tool to mirror any sketch, face, body, or group to a mirror plane:
- Go to Menu > Transform > Mirror.
- Select the sketches, faces, bodies, construction geometries, images, or groups that you want to mirror.
They should be highlighted in blue and labeled with the tool badge. - Select a face, sketch region, grid, axis, sketch line, or construction plane to use as a mirror plane. They should be highlighted in purple and labeled with the target badge. The target plane is the mirror plane that you can use to reflect the tool bodies.
Notice that the Keep Originals switch is turned on by default, so the original items that were mirrored are retained. -
Turn off the Keep Originals switch if you don’t want to keep the original items. The switch label then changes to Keep Originals: OFF.
Select Done.
💡Shortcut💡: If you first select the objects you want to mirror, the menu is customized automatically. From this adaptive menu, go to More > Transform > Mirror.
When you’re done mirroring the objects, select Done.
