You can capture a screenshot of your Mac to save an image of your design, but that’s not ideal when you want to present your design in a professional way. You’ll still see the grid, edges, and UI elements.
Instead, you can export your design as an image with Shapr3D’s Screenshot tool, so you can showcase your work with a polished look and a transparent background.
Screenshot tool
You can use the Screenshot tool in five steps:
- Open your design in Shapr3D.
- Go to File > Export...
The following will appear. - Select Image in Usage.
- Select Next.
The Screenshot tool will open. -
Customize how you want your exported image to look.
: Render your design with or without edges.
: Remove or keep the grid in the background.
: Make the background transparent or filled.
: Choose which items to display.
- Click the Shutter button to capture the screen.
- You can name the exported image and save it locally.
