All your designs and projects are stored locally on your Mac.
If you have a Pro license, then you can export your projects to third-party cloud apps in all supported formats and export 2D drawings in DXF, DWG, or PDF format.
If you're using Shapr3D Basic, which is the free version, then you can only export your projects to low-quality STL and low-resolution 3MF.
