You can intuitively navigate, edit, sketch, and model with a tablet pen and your fingers in Shapr3D. But if you don’t have a pen, you can use a keyboard with a mouse or touchpad to interact with the app and type in dimensional values. You can also easily sketch and model with a Wacom device.
Here’s a cheat sheet that’ll show you shortcuts and basic gestures for the mouse, touchpad, and Wacom device.
Navigation
Rotate camera |
Hold down the Control and Shift keys and move your finger on the touchpad |
Hold down the Shift key and drag or hover over the tablet with your pen |
Move camera |
Hold down the Control and Alt keys and move your finger on the touchpad |
Hold down the Control key and drag or hover over the tablet with your pen |
Zoom camera |
Pinch in or out with two fingers on the touchpad |
Hold down the Alt key and drag or hover over the tablet with your pen |
Zoom to face |
Hover over a face and press the Space bar |
Rotate 2D view by 90 degrees |
Click the right or left arrow above the Orientation Cube |
Reset view | Ctrl + 1
Switch to front view | Ctrl + 2 | |||||
Switch to back view | Ctrl + 3 | |||||
Switch to top view | Ctrl + 4 | |||||
Switch to bottom view |
Ctrl + 5 | |||||
Switch to right view | Ctrl + 6 | |||||
Switch to left view | Ctrl + 7 |
Selection
Select single part | Click the part |
Select full object | Double-click the object |
Select multiple parts |
Hold down the Shift key and click each part |
Select all
Ctrl + A |
Deselect all |
Delete | Press the Backspace or Delete key |
Sketching
Start sketch | Click anywhere in the design space |
Finish sketch | Press the Enter key |
Add fit point to spline |
Long-click anywhere on the spline
2D drawings
Update 2D drawing | Ctrl + R |
Fit to screen | Shift + 0 |
Zoom to 100% |
Shift + 1 |
Save text and exit from Note tool |
Add new line
Shift + Enter |
Add new paragraph
Indent paragraph
Press the Tab key |
Copy text style
Ctrl + Alt + C |
Paste text style
Ctrl + Alt + V |
Italicize text
Ctrl + I |
Underline text
Ctrl + U |
Strike through text |
Ctrl + Shift + S |
Other
Undo | Ctrl + Z |
Redo | Shift + Ctrl + Z |
*Images from Microsoft and Wacom
