If you received a coupon for a yearly subscription to Shapr3D, then you have to redeem it with a subscription purchase.
- Go to shapr3d.com/pricing and select Buy now.
The following popover appears. - Select the country you’re located in and click Continue.
The following popover appears. - Select Add Coupon.
The following appears. - Enter the code you received.
- Select Add Coupon. If your coupon is valid, you’ll see the discount applied to your total. You can then continue the purchase process.
