Everything you need to know about connecting your designs to your Shapr3D account:
- Why should I link designs to my Shapr3D account?
- I'm not subscribed to a paid plan. Do I still need to link designs to my Shapr3D account?
- Will Shapr3D become a cloud-based product in the future?
- If I link my designs to my Shapr3D account, will my designs automatically sync from now on?
- Can I still access my designs locally on my device after I link my designs to my Shapr3D account?
- What's the benefit of linking designs to my Shapr3D account?
- How do I link designs to my Shapr3D account?
- Can I link some designs to one Shapr3D account and the rest to my other accounts?
- I can't see my designs. What should I do?
- I linked my designs to the wrong Shapr3D account. What should I do?
- I linked my designs to an account for a free plan and I can't export my designs. What do I do?
In the future, the Shapr3D app will have features that need your Shapr3D account and designs to be connected — namely Shapr3D Cloud's design sync feature. If your account and the work you create are not linked, the design sync feature will not be able to work properly and safely. Please note that linking designs to your account doesn't affect how you use Shapr3D today.
Even if you're currently using the Basic plan (which is the free version of Shapr3D), you need to link your designs to your account so you can use Shapr3D Sync. Linking will not affect your current Shapr3D experience.
No. Shapr3D Cloud will be optional for users and you're free to opt in or out of it anytime. Your designs will continue to be stored locally on your devices, and Shapr3D Cloud will only be used to sync designs between your devices and back up your files.
Note: For new users with a software version of 5.290 or later, Sync is automatically enabled. To learn how to disable sync, visit this article.
If I link my designs to my Shapr3D account, will they automatically sync from now on?
Yes, but you can always disable Sync. To learn more, visit this article.
Can I still access my designs locally on my device after I link them to my Shapr3D account?
Yes. Your designs will continue to exist locally on your device, so you'll be able to access them whenever you want as long as you're logged in to the linked account on that device.
You'll have the option to sync your designs across your iPad, Mac, and Windows devices.
Shapr3D Cloud is the solution you need if:
- You're getting a new device and you need to transfer your designs from your old device to your new one.
With Shapr3D Cloud, you won't have to manually export each design from your old device and import each design to your new device. - You want to work on the same design on multiple platforms.
With Shapr3D Cloud, your designs will be up to date on your devices and any changes will be automatically synced across all devices. You can pick up where you left off on a different device.
In a nutshell, you have to link all existing designs on your device to your Shapr3D account. Follow these steps:
- Open the app (version 4.11 or newer) and log in to your account that you want to use for Shapr3D Cloud.
The following dialog will appear. - Select Link Designs.
If you'd like to associate the designs with a different account, select Switch Account.
Once you link designs to your account, you'll only see those designs when you're logged in to that account.
No. You can only link all designs to one account. If you need to separate designs between multiple accounts, first link your designs to an account which is subscribed to Pro; this way, you can manually export your designs in various file formats and import them when you're logged in to your other accounts. Then, link those designs to the relevant account.
You can relink the designs to a different account:
- Open the app and log in with the account that was incorrectly connected to the designs.
- Export all designs.
- Log out.
- Log in again with the account that needs to be associated with the designs.
- Import the designs.
The imported designs will be automatically linked to the account.
I linked my designs to an account for a free plan and I can't export my designs. What should I do?
Please create a support ticket here for customer support.
Make sure you're logged in to the account which is linked to the designs you're missing. Once you link your designs to a specific account, you can only see those designs when you're logged in.
