ℹ️ Shapr3D’s Screenshot tool is available only to Pro users.
You can capture a screenshot of your device to save an image of your design, but that’s not ideal when you want to present your design in a professional way. You’ll still see the grid, edges, and UI elements.
Instead, you can export your design as an image with Shapr3D’s Screenshot tool, so you can showcase your work with a polished look and a transparent background. Or, you can get a real-time visualization of your solid and mesh bodies—displayed via Microsoft's 3D Viewer app.
Screenshot tool
You can use the Screenshot tool in five steps:
- Open your design in Shapr3D.
- Go to See more > Export in the top right corner.
- Select the appropriate file format.
Customize how you want your exported image to look.
: Render your design with or without edges.
: Remove or keep the grid in the background.
: Make the background transparent or filled.
: Choose which items to display.
- Select the Shutter button to capture the screen. The exported image will automatically save to your device.
