In Shapr3D, everything starts with a sketch. It’s the foundation of your 3D models. To sketch, use your pen or mouse/touchpad to draw different types of lines with the tools offered in the Sketch menu.
If you’re using a pen, you can draw a line or arc from one button: Line/Arc. With this tool, you can choose which type of line you want to create:
Automatic
The app automatically recognizes your intent and switches to “Line” or “Arc.”
So, you can actually switch from arc to line and vice versa because the app detects your intent; optionally, you can wiggle your pen to switch between Line or Arc. -
Line
Only draws straight lines. -
Arc
Only draws arcs.
If you’re using the mouse or touchpad, the Line/Arc tool is separated into two tools: Line and Arc.
Follow these steps to draw your sketch:
Switch to 2D view.
You can either double-tap the plane with your fingers, or change the view from. For more details, refer to this article.
If you’re using a mouse, hover over a face and press the Space bar.
If you’re using the touchpad, double-click a face with two fingers.
Select Sketch.
Note: If you’re using a pen, then instead of selecting Sketch each time you want to draw, you can start drawing on the plane; the Sketch menu will automatically appear, so you can later refine the drawing. -
Use the sketch tools to draw lines, arcs, splines, polygons, and other shapes, and constraint tools (or auto-constraint) to fine-tune your drawing. You can use snapping to make your sketches more precise as well.
- If you're drawing a line or arc with your pen, then simply tap to add endpoints.
If you're drawing a line or arc with your mouse or touchpad, then click to add endpoints. An arc requires a third point. To place the last temporary line segment and finish the line or finish the arc, press the Enter key. To remove the last temporary line segment or remove the arc, secondary-click (right-click) with your mouse or press one of the following:
- Backspace
- Escape
- If you're using the mouse or touchpad, press the Escape key to drop the active sketching tool. This way, you can easily select sketches.
Select and drag endpoints to adjust your sketch. You can also edit the dimensions by selecting the dimension label and entering a new value. If you’re using the keyboard, then you can type in a value as you’re drawing and press Enter to finalize the dimension of the sketch.
When you select it, the point’s color changes to blue; then, you can drag it anywhere. To deselect the point, tap or click anywhere on the empty area.
- Tap or click on an empty surface or Close when you’re done.
If you create a closed sketch, you can create 3D models from them; a closed sketch’s filling should be selectable and light blue in 3D view. When a sketch is closed, they automatically become profiles for extruding, sweeping, lofting, and revolving.
Watch this video:
