Use the Split Body tool to cut apart 3D bodies with construction planes, grid planes, sketch fillings, faces, or images.
Follow these steps to split bodies in the design space:
Go to Menu > Tools > Split Body.
Select the bodies that you want to split. They should be highlighted in blue.
Select a construction plane, grid plane, sketch filling, face, or image. It should be highlighted in purple.
The surface extended from the geometry will be used as a plane that cuts the bodies.
Note: If you want to choose a different geometry as the splitting plane, select a different one. -
Turn on the Keep Originals switch if you want to keep the original bodies.
Select Done.
If the Keep Originals switch was off, the body will be split like this:
If the Keep Originals switch was on, the body will be split like this:
💡Shortcut💡: If you select the bodies and the splitting geometry, the menu is customized automatically. From this adaptive menu, go to Menu > Split Body.
