Show, don’t tell. With the app’s visualization tool, you can make your models realistic and aesthetic with materials and color.
In your design space, go to Tools > Visualize to start using visualization.
From the Material tab, choose any of the ready-made 70+ materials and finish types so you can customize your models to be exactly how you imagine the end product to be. The materials you've applied will show up in Used Materials.
Then, select the Environment tab to switch up the background — default gray, transparent, solid color, or gradient — and place the models in virtual environments.
Once you apply the materials, you can tailor your model with color, transparency settings, light rotation and intensity, material scaling, and more. For details about adding color, head on over to this article.
Then, select Capture to get snapshots of your visualized prototypes and bring them to presentations, client meetings, etc., and speed up the decision-making process. And if you notice anything in your model that needs some tweaking, you can instantly switch between the modeling and visualization spaces to do what you need to do. The changes will be immediately synced between the spaces so you don't lose even a second.
