Manage projects and folders
You can manage your projects from two main sections in the Shapr3D Dashboard: Recents and Spaces.
Recents
Recents shows your most recently opened or modified projects across all spaces. From here, you can quickly open, rename, show versions, export, or delete a project.
For more advanced actions like organizing projects into folders or restoring project versions, switch to the Spaces view.
Spaces
Under Spaces, you'll find your shared and private projects organized under Teamspace and Private
Create a new project
You can create a new project directly from the Teamspace or Private space.
To create a new project:
  1. Go to the space you want to create a project from.
  2. From the top bar, select New  icon-dashboard-add-win.png.
Import a new project
To import a project into the Teamspace or Private space:
  1. Go to the space where you want to import a  project.
  2. From the top bar, select  icon-dashboard-import-mac.png or  icon-dashboard-import-win.png .
Rename a project
To rename a project:
  1. Right-click (secondary click) or long-tap on a project or folder.
  2. Select Rename.
Selecting projects
You can select projects in the Dashboard to manage them individually or in groups.
Selecting a project
To work with a single project, select it and open the context menu:
  • Windows: Right-click on the project.
  • iPadOS: Tap and hold the project.
  • macOS: Secondary click on the project.
Selecting multiple projects
To manage multiple projects, select them first, then open the context menu for batch actions:
  • Windows: Click icon-dashboard-select-win.png  to select the projects, then right-click to open the context menu.
  • iPadOS: Tap Select to choose the projects, then tap and hold to open the context menu.
  • macOS: On your keyboard, press and hold Shift to choose the projects, then secondary click to open the context menu.
Duplicate a project
To duplicate a project:
  1. Select the project(s) you want to duplicate.
  2. Right-click (secondary click) or long-tap on your selection to open the context menu.
  3. Select Duplicate.
Restore Project Versions
You can view or restore previous versions of your projects by right-clicking on a project and selecting Show Versions. To learn more, visit Project Versions.
Quick export projects to your favorite formats
Effortlessly export your projects to your favorite formats using the Quick Export option in the Dashboard. With this feature, you can select multiple projects and export them all at once, making your workflow smoother and more efficient.
To export your projects to your favorite formats:
  1. Select the project(s) to export.
  2. Right-click (secondary click) or long-tap on any of your selected projects.
  3. Select Quick Export to Favorite Formats.
  4. Select a folder or location to save your projects.
Export a project to .shapr file
To export a project to a .shapr file:
  2. Select Save as .shapr file.
Create and manage folders
You can create folders under Teamspace or Private to organize your projects more easily. You can find your created folders in both the main Dashboard and Dashboard sidebar.
To create a new folder:
  2. When prompted, enter a folder name and then select Create.
To organize projects and folders into other spaces or folders, do any of the following:
  • Drag and drop projects or folders from either the main Dashboard or Dashboard sidebar within or across the Teamspace or Private space.
  • Secondary click (right-click) on projects and folders and then select New Folder with Selection to automatically move them into a new folder.
Folder navigation
You can navigate between folders and subfolders using any of the following options:
  • Directly from the Dashboard sidebar
  • By using the navigation arrows for iPadOS and macOS
  • By using the breadcrumbs for Windows to navigate
To navigate between folders using the navigation arrows or breadcrumbs:
  • Windows: From the breadcrumb trail at the top, click a folder or subfolder name to go back to its location.
  • iPadOS/macOS: Click or tap any of the back or next arrow keys at the top to go to the next or previous folder location.
Sort projects
To sort projects within a space, click/tap Sort icon-dashboard-sort-mac.png from the top bar and then choose a sorting type:
Windows:
  • Date modified – Sorts projects by date.
  • Name – Sorts projects and folders by name.
  • Ascending – If Date modified is selected, projects sort in ascending order.
  • Descending – If Name is selected, projects and folders sort in descending order.
iPadOS/macOS:
  • Date Modified (Latest to Oldest) – Sorts projects by date in descending order.
  • Date Modified (Oldest to Latest) – Sorts projects by date in ascending order.
  • Name (A to Z) – Sorts projects and folders by name in ascending order.
  • Name (Z to A) – Sorts projects and folders by name in descending order.
Delete a folder or project
To delete a project or folder:
  1. Select the project(s) you want to delete.
  2. Right-click (secondary click) or long-tap on your selection to open the context menu > Delete.
  3. To confirm the deletion, select Delete.
Important
All projects are automatically synced to the cloud. When you delete a project, it’s removed from all devices and can’t be recovered. To keep a backup, export the project before deleting.
292 out of 340 found this helpful
