You can find all your work in the Designs tab in the Shapr3D Dashboard.
To access the Designs tab, open Shapr3D and then select Designs. In this tab, you can:
- Create a new design
- Import a design
- Rename your design
- Duplicate your designs
- Delete your design
- Enable Sync
Create a new design
You can create a new design from the Designs tab in the following ways:
- iPadOS: Select the tile with a plus icon > New Design, or select New at the top-right corner.
Note: You can also create a new design from the Discover tab. - macOS: Select the New Design tile with the plus icon, or select the plus icon at the top-right corner.
- Windows: Select the New Design tile with the plus icon, or select New Design at the top-right corner.
Import a design
You can import designs from the Designs tab in the following ways:
- iPadOS: Select Import at the top-right corner.
- macOS/Windows: In the top bar, select the Import icon.
To learn more about importing designs and the other ways to import files, visit Import.
Rename your design
After you create your designs, you can always rename them in the Designs tab.
- Touch or pen: Press and hold the design name with your pen or finger and use the on-screen keyboard to type the new name.
- Keyboard or mouse/trackpad: Secondary click (right-click) on a design, then select Rename.
If you want to copy or duplicate your designs, you can do so in the Designs tab.
- Touch or pen:
- Tap and hold on a design tile. This activates the edit mode, allowing you to select multiple designs.
- At the top-right corner, select Edit, then select the designs you want to duplicate. Tap Done to finish.
Note: The name of the duplicated designs will have the same name as the original with the word "Copy" at the end.
Delete your design
A deleted design can't be recovered. If Sync is enabled and you delete a synced design, the design will be deleted from all devices. You can keep a copy of your design before deleting it by exporting it.
- Touch or pen:
- At the top-right corner, select Edit, then select the designs you want to delete. Tap Done to finish.
- Keyboard and mouse/trackpad: Secondary click (right-click) on a design, then select Delete.
Enable or disable Sync
You can quickly enable or disable Sync from the Designs tab:
- iPadOS: In the top-right corner, select the Sync icon > Enable Sync Across Devices.
- macOS: In the top bar, select the Sync icon > Enable Sync Across Devices.
- Windows: In the top bar, select the Sync icon > Enable Sync Across Devices. You can also select the Settings icon in the top bar to enable Sync from there.
To learn more about Sync, visit Shapr3D Sync.
