The numpad, or numpad calculator , is used to define numerical values for your projects. The numpad becomes available when you select a dimension label. You can enter values directly in the numpad or calculate a value by using the calculator functions.
Some dimension labels, such as the quantity for patterns, display a simplified numpad that does not include the calculator functions.
To enter a value in the numpad, use the following methods:
- Keyboard and mouse/trackpad: Type numbers and mathematical operators from the keyboard. Press Enter to complete the numpad.
Note: When using a keyboard, you can type dimension values directly into an active dimension label without activating the numpad. For more information, visit Editing sketch dimensions. - Touch and pen: Select buttons in the numpad using touch or the cursor.
