To sketch in 2D, you must define a sketch plane where you want to create your sketch. You can define a sketch plane in the following ways:
- From the Orientation cube
- From Views in Views and Appearance
- By selecting a planar face or construction plane
To select a sketch plane or construction plane using specific input devices, expand the sections below:
Touch or pen
Using a finger, double-tap on a planar surface or construction plane.
Keyboard and mouse/trackpad
- Drag your cursor to hover over a planar face or construction plane.
- Press the Space bar, or you can use your mouse or trackpad:
- For mouse: Double right-click (secondary click).
- For trackpad: Double-click or double-tap with two fingers.
