Video tutorials
SetupSketchConstraintsDocumentationDesign HistoryVisualizationProjectLoftBooleanImport
Getting started
Starter guide
Master Shapr3D basics. Matt Lombard, mechanical engineer and CAD expert, walks you through sketching, modeling, Visualizing, and documenting motorcycle parts to gain hands-on practice designing in Shapr3D.
INTRODUCING SHAPR3D BASICS
SetupSketchModelingDocumentation
Learn sketching, modeling, visualizing, and documenting motorcycle parts for hands-on practice. Discover the ins and outs of Shapr3D, from setting up your modeling space to leveraging its Selection-Based Interface and expansive toolbox.
GET STARTED: A SHAPR3D OVERVIEW
IntroductionNavigationInput deviceSettings
Jumpstart your design process in Shapr3D with this introductory overview from Mechanical Engineer and CAD expert, Matt Lombard. Professionals can create, edit, and share designs on a history-based modeler, all while on the go, working from any device. Tour the interface, input devices, plans, and more to learn everything you need to know to get familiar with and get started in Shapr3D.
HARDWARE AND INPUT DEVICES
SetupInput devicesPeripheralsHardware
Run Shapr3D on your existing devices and work with the input device of your choice. Explore a variety of setups to fit your workflow — no specialized hardware or equipment needed.
GRID AND SKETCH SETTINGS
Modeling viewControlsSettingsSketch
Start a new project and set up your space. CAD expert, Matt Lombard, shows you how to control the view of your modeling space, adjust settings, and begin sketching basic shapes.
CONTROL YOUR MODELING ENVIRONMENT VIEW
Keyboard shortcutsNavigationModelingViews
Explore how to move around your modeling space. You get best practices for your chosen input devices, go-to keyboard shortcuts, selecting navigation presets, and working with navigation islands for section views, construction planes, and more.
INTRODUCTION TO 2D SKETCH TOOLS AND SETTINGS
SketchLineRectangleCircle
Get familiar with basic sketching in Shapr3D crafting a cover for a motorcycle design. You learn how to adjust basic settings for your sketch, create a sketch, set it into place, and switch between tools.
CREATING COMPLEX SHAPES
SketchLineConstraints3D shapes
Use basic shapes and lines to create the more unique, complex shape of a motorcycle cover design. You learn how to use various line types and set relationships between shapes. Then, form a 3D shape out of your 2D sketch as the basis for your motorcycle cover design.
CREATE BASIC 3D GEOMETRY
ShellFilletOffset SketchHistory
Explore how to create basic 3D geometry to craft your motorcycle design model using the Sketch Offset, Shell, and Fillets and reordering History-based features. Finally, add text to your model with sketch text.
MODIFY FEATURES WITH DESIGN HISTORY
ParametricHistoryDesign HistoryHBPM
Learn how to modify features quickly using design history. Continuing with the motorcycle cover design, you get familiar with History-based parametric modeling in Shapr3D and reorganizing steps to make features match your vision.
ORGANIZE DESIGN HISTORY STEPS
FilletAdd HistoryHistoryVisualization
"Where do you place fillets in your design history to give your motorcycle cover design edges the right curvature? Learn how to place fillets in Design History using breakpoints to reorder features. With your model finalized, now you can add the materials of your choice to a real-time 3D render in Visualization."
SKETCH AND REVOLVE
LineDimensionRevolveSketch
Get familiar with sketching, dimensioning, revolved features, and general workflow designing the wheel of a motorcycle. You learn how to set relationships between lines, angles, and shapes to quickly sketch and use the Revolve tool to create a 3D model.
BODIES AND PATTERNS, PART 1
MirrorPatternDesign HistoryHBPM
Learn how to work between Design History and Patterns to create new bodies, pattern them, and mirror them, ending up with a pattern of holes in your motorcycle wheel.
BODIES AND PATTERNS, PART 2
LOFT AND CONSTRUCTION GEOMETRY
LineSplineLoftConstruction plane
Create the framework for motorcycle handlebars working with the spline tool, construction planes, and a guide curve.
COMBINE SKETCH TOOLS AND ADJUST WITH DESIGN HISTORY
LoftShellMirrorSketch
Complete the motorcycle handlebar design by using the Loft tool to create the full shape and Shell to hollow it out. You’ll add and combine bodies and organize Design History to create relationships, adjust features quickly, and then finalize the design using the Mirror tool.
WORKING WITH THE REVOLVE TOOL
LineConstraintsDimensionRevolve
Set symmetrical relationships between lines, radial dimensions, and use the Revolve tool to create the fender of a motorcycle.
DESIGN HISTORY TIPS WITH UNION, SHELL, FILLET, PART 1
ShellFilletBooleanHistory
Learn tips for leveraging Design History while working with Union, Shell, and Fillet tools to get the right fender shape for your motorcycle design.
DESIGN HISTORY TIPS WITH UNION, SHELL, FILLET, PART 2
REVOLVE, SUBTRACT, AND MIRROR
LockRevolveMirrorSubtract
Create the first part of the gas tank starting with a block and cutting it away to achieve the right curvature working with the Revolve and Subtract tools. Cut your work in half by modeling half of the model and then mirroring it.
SHAPE AND ADD DETAILED FEATURES
LineArcRevolveConstraints
Shape and add detailed features by trimming shapes using arcs, center lines, and the Revolve tool in combination with each other. This allows you to revolve a cut to form half of the motorcycle gas tank.
ADDING INDENTS AND FILLETS
ArcChamferFilletAdaptive User Interface
80% of your CAD work is generally edits. Learn how to quickly edit shapes, adding indents and fillets using Shapr3D’s Selection-Based Interface (SBI) to your motorcycle gas tank. With SBI, you preselect items, then pick from a list of appropriate features, replacing the time you would spend searching through menus with more focused design work.
PRIMARY AND SECONDARY FILLETS
ChamferFilletDesign HistoryHBPM
Set up secondary fillets to flow around the primary fillets, easily reordering Design History features to create the right shape and working with Hidden Edges to adjust any edges. You also get troubleshooting tips for when you run into an error crafting your model so you can adjust and keep modeling smoothly.
MIRROR AND UNION
MirrorFilletUnionTransform
Complete the tank body using the Mirror, Transform, and Union tools and get introduced to the Measure tool to get a rough estimate of the volume of the tank. Next, you add and fillet a gas filler neck to the tank, simply selecting the feature to easily work with relevant steps in Design History.
MEASURE PRECISE VOLUME
RectangleHistorySubtractMeasure
Learn the process for calculating volume of a select body. You walkthrough creating a new body from a rectangle placed around the motorcycle gas tank, using the Subtract tool, and working with Design History to keep tool bodies and then calculate the volume of the tank.
LAYOUT SKETCH TECHNIQUE
ProjectSketchDesign HistoryHBPM
Master the layout sketch technique for laying out the general parameters of your project.
EXTRUDE WITH ADAPTIVE USER INTERFACE
ExtrudeSweepConstruction PlaneAdaptive User Interface
Start creating the 3D motorcycle frame by adding ‘On Curve at Point’ construction planes and using the sweep tool to follow the parameters you set out. You get more familiar with Shapr3D’s Selection-Based Interface which auto-suggests tools to match your selection, making modeling faster.
MIRROR FRAME COMPONENTS
SweepMirrorSketchConstruction Plane
Mirror sections of your motorcycle frame using ‘Along Plane at Edge’ Construction Planes and learning how to drag your sketch onto the construction plane, then using the Sweep and Mirror tools to complete your frame.
MIRROR AND UNION BODIES
MirrorAddBooleanUnion
Get more tips for quickly mirroring bodies by creating them as new bodies first and using the Union tool to add more components to the frame.
TROUBLESHOOT GEOMETRIC ERRORS
ShellDesign HistorHBPMTroubleshooting
Why do errors sometimes come up while you’re modeling? Learn why geometric errors occur and how to go about troubleshooting them with this walkthrough of shelling a motorcycle frame.
IMPORT MODELS
Design HistoryAlignImportAdaptive User Interface
Leverage Shapr3D’s all-around compatibility to import parts and explore bottom-up design creating this motorcycle engine. You can quickly align and edit parts, including an imported block casting, crank, and piston rod using Shapr3D’s Selection-Based Modeling Interface to get a smooth process making them fit together.
DESIGN HISTORY AND IMPORTING
Design HistoryImportAssemblyHBPM
Get tips for importing and assembling models, working the Design History to keep the model precise and history organized.
SECTION VIEW AND ISOLATE
AlignImportIsolateSection View
Learn how to check part alignment after importing working with Section View and Isolate to ensure that all components are placed correctly relative to each other.
MANUFACTURE-READY 2D DRAWINGS
Projection ViewDetailed ViewDocumentation2D Drawings
Walkthrough how to create manufacturing-ready 2D Drawings from your model for easy handover to production. You follow a step-by-step process including how to add views using the View Projection tool, selecting format, adding Section and Detail views, tolerances, and more.
Sketching fundamentals
Double down on sketching fundamentals with this 8-part tutorial series from CAD educator, Claas Kuhnen. You’ll learn everything from positioning your sketch to creating a curve network. Explore here.
INTRODUCTION TO SKETCHING
SketchConstraintsHistoryHBPM
Welcome to Sketching Fundamentals! In this opening lesson, your instructor Claas Kuhnen, Industrial Design Faculty at Wayne State University and founder of Studio Kuhnen, breaks down what sketches are and how they work in Shapr3D, covering how to create and edit sketches, generate geometry, and drive your design with history-based parametric modeling.
CREATE SKETCHES
SketchConstruction planeHistoryHBPM
Learn how to create and position sketches anywhere in 3D space: on a construction plane, a planar face of a body, or directly on the world grid.
SKETCH CONSTRAINTS AND SPLINES
SketchLineSplineTangent
Learn how to draw lines, arcs, and splines, then use dimensions and constraints to lock your sketch into a fully defined, predictable shape.
SKETCH WITH DESIGN HISTORY
SketchLineHistoryHBPM
See how design history and variables work together to keep your model flexible from start to finish.
MASTERING THE PROJECT TOOL
SketchProjectHistoryVisualization
Go deep on the Project command and see how it can drive complex design decisions.
DEFINE YOUR DESIGN WITH CURVE NETWORKS
SketchEllipseSplineLoft
Learn how to build curve networks by combining cross-section sketches with rail curves to give Loft precise control over the shape of your model.
CONNECTING SKETCHES USING COINCIDENCE CONSTRAINTS
SketchConstraintsSymmetryCoincident
Discover how Shapr3D's sketch guide system automatically adds constraints as you draw, helping you work faster without relying on the grid.
SKETCH PATTERN
SketchConstraintsPatternHistory
Learn how to create circular and linear sketch patterns, control spacing, quantity, and rotation, and use variables to keep everything parametrically linked.
3D modeling fundamentals: Extrude, Revolve, Loft
In this course, 3D designer and educator Claas Kuhnen walks you through the three essential tools of 3D modeling in Shapr3D — Extrude, Revolve, and Loft. You will learn what each tool is designed for, where to apply it, and how to combine all three in a full design walkthrough.
INTRODUCTION TO 3D MODELING
ExtrudeRevolveLoftHistory
Welcome to 3D Modeling Fundamentals: Extrude, Revolve, and Loft. In this course, 3D designer and educator Claas Kuhnen gives you a solid foundation in the essential tools of 3D modeling, focusing not just on how they work, but where and when to apply them.
THE EXTRUDE TOOL
Learn how the Extrude tool works and when to use it. This lecture covers transforming 2D sketch profiles into 3D geometry along a single direction, and refining bodies using Face Offset, Shell, and Boolean operations like Union and Subtract.
THE REVOLVE TOOL
Understand when the Revolve tool is the right choice for your geometry. This lecture covers creating sculpted forms by revolving a cross-section around an axis, and using control point splines and constraints to define and refine more complex, expressive profiles.
THE LOFT TOOL
Explore what the Loft tool makes possible that Extrude and Revolve cannot. This lecture covers connecting multiple profiles to create flowing, organic transitions, and working with rails, splines, and G1 and G2 surface continuity to control the result.
FULL DESIGN WALKTHROUGH
Work through a complete modeling session that draws on all three tools. This lecture covers how to approach a design challenge strategically — combining tools, managing Design History, and refining a model step by step from initial proportions to a finished, presentation-ready result.
Modeling essentials
Solid modeling
Master the essentials of solid modeling basics in this tutorial series lead by Industrial Design Expert, Andrew Camardella.
INTRODUCTION TO SOLID MODELING
SketchSolid modelingSolid modelingHistory
Master the essentials of solid modeling basics in this tutorial series lead by Industrial Design Expert, Andrew Camardella. Cover everything from combining direct modeling and design history, sketching, and basic and advanced tools, plus Design for Manufacturing best practices to kickstart your 3D design workflow with solid modeling.
DIRECT VS PARAMETRIC MODELING
ModelingHistorySolid modelingHistory
What’s the difference between direct modeling and design history in the solid modeling environment of Shapr3D? Learn how to select individual surfaces and modify them with direct modeling and adjust features in the history tree, both leveraging Shapr3D’s selection-based interface for faster, more focused modeling. You’ll best practices for working with design history like suppressing features and inserting breakpoints.
SOLID MODELING FROM SKETCHES
RevolveOffset FaceSolid modelingHistory
In this video, you’ll add to the sketches you created in the previous session, creating solid models to add more details to your water pick model. Learn key modeling tools like Revolve, Subtract, and Offset Face and work with design history to adjust features like adding an extrusion. You’ll get insight into working with a Design for Manufacturing mindset, ensuring your model is best suited for manufacturing.
SOLID MODELING
SweepProjectSolid modelingHistory
Continue modifying the waterpick model shape, adding more shapes using advanced features like Sweep, Project, and Pattern. Work with different views of the model, including Section View, to double-check your geometry for manufacturing.
ADVANCED PART DESIGN
DimensionConstraintsSolid modelingHistory
Check out how to keep Folders as design history steps organized as well as layout dimensions and constraints to keep your design practices consistent and improve your overall workflow.
COMPLEX DESIGN
SketchConstraintsSolid modelingHistory
Walk through how to sketch the underlying structure that you’ll later use to create geometry for your model in Shapr3D. You’ll practice using key sketch tools and working with constraints to get the final underlying sketch for a waterpick model.
HOUSEKEEPING
Conceptual design
Daniel Brunsteiner, Industrial Designer, navigates you through using Shapr3D for conceptual design and tips on which tools to use for an easier workflow.
INTRODUCTION TO CONCEPTING
HBPMDesign HistoryHistoryConceptual design
Dive into conceptual design with Shapr3D with this introduction to best conceptual tools in Shapr3D and using design history to create versions of project for quick iteration.
CONCEPTUAL DESIGN
SketchItems managerHistoryConceptual design
In this introduction to conceptual design, you’ll learn how to save time and quickly get ideas across doing quick iterations in 3D just as if you were sketching on paper. This helps you to determine if your ideas make sense in the 3D world.
CONCEPTING FUNDAMENTALS
SketchConstraintsHistoryConceptual design
Learn how to import a hand-drawn sketch into Shapr3D and create a basic sketch of a laundry detergent model while working with constraints.
HISTORY AND EXTRUDE
ExtrudeHistoryHistoryConceptual design
Learn how to adjust the shape of your design quickly by adjusting parameters for quick updates across your model’s history and directly editing model geometry in combination.
HISTORY AND REAL-TIME PREVIEWS
SketchAddHistoryConceptual design
Create a complex detergent bottle model, extruding the sketches of the outside and inner contours and adding a handle cutout. Then utilize History-based Parametric Modeling to quickly adjust feature details and iterate on your design.
DESIGN VERSIONING WITH HISTORY
AddModelingHistoryConceptual design
Get a walkthrough of creating iterations and working between direct and parametric modeling to edit elements of your copy directly as well as copy feature details from the original model’s design history to add to your iteration.
VISUALIZATION
VisualizationMaterialsEnvironmentConceptual design
Get an introduction to visualizing your laundry detergent model, selecting an environment, materials, and colors — all your edits show instantly for prompt communication and finalization.
ITEMS AND EXPORTING THE MODELS
Items ManagerExportingHistoryConceptual design
Create and organize folders for your laundry detergent model’s different concepts and sketches, creating a clean space to view and decide on iterations of your concept. Select from the wide range of file options to export and share your model for viewing.
Design for manufacturing
Follow along with Andrew Camardella, Industrial Designer Consultant and Faculty Member at DePaul University, as he shows you how to turn an existing lamp design into a manufacturable model.
DESIGN FOR MANUFACTURING COURSE
Prepare for manufacturingTemplatesDiesHistory
Follow along with Andrew Camardella, Industrial Designer Consultant and Faculty Member at DePaul University, as he shows you how to turn an existing lamp design into a manufacturable model. You’ll create all the templates, dies, and tools to fabricate the components out of real materials, preparing the lamp model for production.
DESIGN FOR MANUFACTURING BASICS
Prepare for manufacturingItems ManagerAdaptive user interfaceHistory
Start off exploring how to make initial adjustments to each model component to improve manufacturability, leveraging Shapr3D’s design history. You get introduced to Shapr3D’s adaptive user interface and adaptive parametric modeling while going through various options for tools to tackle adjustments.
ADJUSTING COMPONENTS
Prepare for manufacturingSketchAdaptive user interfaceHistory
DIES AND TOOLS FOR FABRICATION
Prepare for manufacturingSubtractMove/RotateHistory
To make a die for a base plate, you’ll form a block around the base plate and use the Subtract tool to create a pocket inside of the block. Adjust design history to reorder steps and adjust additional target bodies.
TRANSFER PUNCH DIE
Prepare for manufacturingChamferProjectHistory
Continue making a template that acts as a jig to hold a transfer punch for the lamp base plate. You’ll walk through projecting the base plate onto the surface of a block to trim and cut from a duplicate die and form the jig using tools like subtract and chamfer.
LAMP BASE COVER DIE
Prepare for manufacturingSketchConstraintsExtrude
Make a single die holding four welded pieces together to construct the lamp base cover. After projecting sketches onto your sketch plane, you’ll extrude the template, making space for clamps and including reliefs to prevent welding damage to the overall template.
CLAMP AND ROUTER TEMPLATE FEATURES
Prepare for manufacturingMirrorOffset EdgeHistory
To finalize the lamp base tool, you’ll extrude bottom and side clamp holes as well as define the top surface area for the router to follow. This includes offsetting the base profile, constructing the clamp area, extruding, and mirroring to create bottom clamp holes, followed by creating a box around the top of the base to then extrude away.
CONSTRUCT ARM BASE FIXTURE
Prepare for manufacturingSketchExtrudeHistory
Make a fixture that fits directly around the base of the arm part. You’ll use sketch planes and extrude to build a box with spaces for drill holes on the bottom.
TEMPLATE TO DEFINE BASIS SHAPE
Prepare for manufacturingExtrudeOffset EdgeProject
Utilize the box you built as a template around the arm base to define the curvature and slope as well as cut and extrude holes. You’ll project linework onto the bottom and side sketch planes, cutting the overall curvature and slope of the base, and extruding cavities to further define the shape to prepare for router use.
TEMPLATE TO ROUND BASE CORNERS
Prepare for manufacturingHistoryProject
Complete the template for the lamp arm base to include the round corners. To do that, you’ll work between design history and directly editing geometry, projecting the top face onto the bottom surface, and extruding up to create enough room for the router to make the cut.
POSITIVE MOLD
Prepare for manufacturingSubtractExtrudeHistory
Manufacturing the shade leaf of the lamp shade will take two different tools. Learn how to make the first one, a positive mold where the plastic gets molded to the outside of it, directly editing the part, extruding, and subtracting the shade leaf to create the part.
OUTER TOOL SURFACE GUIDE
Prepare for manufacturingMirrorProjectSketch
Start constructing the outer tool to trim the vacuum-formed part by sketching a surface guide on flat faces on top of half of the shade to mirror later on. You’ll use a cross-section of the lampshade leaf and project onto a parallel plane to sketch out features for the tool. This will create flat faces to use to trim away the inner surface of the component.
OUTER TOOL MAIN BODY
Make the main body for the tool by creating a solid that can get cut away and guide a router around the part. You’ll split the lampshade in half to mirror later on. Then follow along with directions on creating a sketch, projecting an entity onto the surface of the sketch, extruding, and subtracting on all the outer faces of the lamp shade to remove extra material and create a travel for the router to follow.
COMPLETE OUTER TOOL
Prepare for manufacturingRevolveMirrorTrim
Complete the outer tool body by cutting out where the hole for the lamp shade leaf and subtracting the inner surface. You’ll use a combination of the subtract tool to create the subtracted body and match outer curvature, revolve extrude to create a relief area, and mirror and union to create complete component. This gives the location of the hole and the track for the router to trim the component all the way around.
MAIN TOOL FOR INNER ARM
Prepare for manufacturingExtrudeSketchHistory
Create the main tool for the inner arm in the same c-shape to wrap laminated wood around, with extra space provided to clamp the pieces together. Walk through how to construct the framework and extrude to build the basis of the tool.
INTERIOR TEMPLATE CLAMP HOLES
Prepare for manufacturingPatternExtrudeHistory
Get step-by-step instructions for creating clamp holes by adjusting the design history breakpoint and working with the pattern tool to create an array of holes along the main tool.
LAMP ARM EXTERIOR TEMPLATE
Prepare for manufacturingParallelOffset EdgeSketch
Make a template to carve out the outside shape of the lamp. You’ll extend the interior template sketch framework using parallel construction lines and offsetting them to create a basis for the outer template. Customize the offset to fit your router bit’s bearing lines and length.
TEMPLATE FOR TRIMMING INNER POCKETS AND GROOVES
Prepare for manufacturingTrimConstruction axisUnion
Cut out a guide in the exterior template to create the groove and hole details in the lamp arm and trim the outer edges including cavities. You’ll build a construction axis, extruding the grooves and holes while excluding bodies in design history, and using subtract and union to create the framework for clamping pieces together and trimming the outer body surface.
TRIMMING TOOL FOR UPPER PART OF LAMP
Prepare for manufacturingSketchChamfer/FilletHistory
Create a trimming tool for the upper part of the lamp, including hole details. You’ll build a feature that keys into the arm c-shape with a flat surface at the bottom to fit appropriate machinery, like a drill press.
TRIMMING TOOL FOR LOWER PART OF LAMP
Prepare for manufacturingSketchTrimHistory
Build a similar trimming tool for the lower part of the lamp, keying into the arm shape and filleting the final shape to provide a complete track for the router along and extruding holes for drilling. You get a foundational part that you can customize to include additional features for keying, clamping, or fixturing.
INSTALLING LAMP POST AND BASE WITH EXTRUDE AND SPLIT BODY
Prepare for manufacturingExtrudeTransformHistory
Walk through adding the final touches to the arm, installing the fabricated lamp post and the bottom base to the arm. You create a feature to key the bottom base to the arm, working with design history as you extrude and fit the base tool to the shape of the arm.
Design for 3D printing
In this three-part series, industrial designer Daniel Brunsteiner walks you through the complete process of designing a product specifically for 3D printing, from the first rough sketch to a finished, assembled print.
Wall Clock Part 1: Concept Design
3D printingExtrudeOffset FaceShell
Industrial designer Daniel Brunsteiner kicks off this three-part series on product design optimized for 3D printing.
Wall Clock Part 2: Real-world dimensions
3D printingProjectExtrudeOffset Edge
In Part 2, Daniel moves from concept to construction by measuring a real clock mechanism and building a precise digital reference model in Shapr3D, then uses those dimensions to design the final clock body around the physical hardware.
Wall Clock Part 3: Hands and assembly
3D printingChamferSubtractProject
In the final part of the series, Daniel completes the wall clock by designing the clock hands, snap-fit connectors, and a clever bending mold — all optimized for 3D printing.
Parametric
Step-by-step modeling projects
Discover the fundamentals of parametric modeling in Shapr3D and learn how to create dynamic models by linking dimensions and features. Each tutorial walks you through a complete design process for a real-life object, complete with step-by-step instructions and handy tips and tricks.
Reverse Engineering an STL File
UnionShellSplit BodyExtrude
Learn how to design a custom electronics housing around imported STL components in Shapr3D.
INTERFERENCE ANALYSIS WITH SECTION VIEW
Section ViewHistoryMirrorConstraints
Industrial designer Daniel Brunsteiner demonstrates how to use Shapr3D’s updated Section View to find and remove collisions in a multi‑position phone charger while keeping iteration fast with Saved Views and targeted history edits.
PARAMETRIC ROBOTIC ARM USING DRIVING SKETCHES
VariablesSweepProjectConstraints
Industrial designer, Daniel Brunsteiner, shows how to design a robotic arm controlled through sketches. The tutorial demonstrates how to control angles, positions, and movement using parametric modeling in one project. Each part follows from sketches and variables that define the system.
CONTROL DESIGN FEATURES USING FRACTIONS IN VARIABLES
VariablesExpressionsFractionsHistory
Claas Kuhnen, industrial designer and educator, shows how to control design features using fractions in Shapr3D. Learn how to use expressions with ratios to define and update model dimensions through variables.
CONFIGURABLE RACK SYSTEM WITH VARIABLES AND EXPRESSIONS
MirrorExtrudeAlignHistory
Industrial designer Claas Kuhnen demonstrates how to build a fully adjustable rack model using Variables and Expressions in Shapr3D. Drive consistency across sketches and features, set global values for wall thickness, angle, or spacing, and explore geometry variations without breaking constraints.
BUILDING A PARAMETRIC CLAMP WITH DRIVING SKETCHES
ProjectExtrudeAlignHistory
Join Industrial Design Consultant Andrew Camardella as he builds a parametric mechanical screw clamp in Shapr3D. This tutorial shows how to set up strong relationships between parts so your designs stay connected and behave predictably when updated.
BUILDING PARAMETRIC MODELS WITH DRIVING SKETCHES
In this tutorial, Gabe Corbett demonstrates how to create a parametric model using driving sketches and the Project tool in Shapr3D. Discover how one layout sketch controls multiple parts and drives mechanical motion in a multi-body setup, allowing you to test different positions, change key parameters, and see real-time updates across the design.
FAST CONCEPT DEVELOPMENT WITH LOFT AND SWEEP
LoftSweepMirrorMove/Rotate
Andrew Camardella, industrial design consultant and professor at DePaul University, shares a straightforward concept development workflow using Shapr3D. This approach focuses on flexibility and speed—ideal for exploring product forms and creating multiple design variations with minimal setup.
ACTION CAMERA MOUNT, PART 5: EXPORT, SHARE, AND COLLABORATE
VisualizationARExportWebviewer
Industrial designer Andrew Camardella continues the action camera mount tutorial series, focusing on exporting, sharing, and collaborating with 3D models.
PARAMETRIC DESIGN WITH VARIABLES AND EXPRESSIONS
SketchFilletShellHistory
Learn how to use Variables and Expressions in Shapr3D with Claas Kuhnen to build more flexible and efficient parametric models. This tutorial demonstrates how to define variables, apply expressions to control dimensions, and modify designs through the History sidebar.
QUICK CONCEPTS PART 3: REFINEMENTS AND HISTORY-BASED EDITING
Offset EdgeLoftSplit BodyHistory
Wrap up your Quick Concepts journey in this final part of the series with Mechanical Engineer and CAD expert, Matt Lombard, refining concept models through history-based editing and direct modeling for flexible, iterative adjustments.
QUICK CONCEPTS PART 2: ITERATE AND MODIFY
SubtractLoftSweepExtrude
Continue your Quick Concepts journey in this second part of the three-part series with Mechanical Engineer and CAD expert, Matt Lombard. This video focuses on iterating and modifying designs efficiently in Shapr3D, making it easy to explore multiple design variations without getting caught up in fine details.
QUICK CONCEPTS PART 1: CONCEPTS OVERVIEW
SketchSettingsRevolveExtrude
Jumpstart your design process in Shapr3D with this three-part video series on Quick Concepts. In this first part, Mechanical Engineer and CAD expert, Matt Lombard, provides an introductory overview of the key tools and techniques for quick concept modeling in Shapr3D.
CUSTOM CASE DESIGN WITH EXTRUDE, OFFSET EDGE, AND UNION
ImportOffset EdgeVisualizationExtrude
Design a custom case for the Raspberry Pi 5 single-board computer with Mechanical Engineer Gabe Corbett. This tutorial demonstrates Shapr3D’s versatile tools to create precise enclosures by referencing imported geometry.
ROTATING ORGANIZER TRAY WITH REVOLVE, SHELL, AND CIRCULAR PATTERN
RevolveShellVisualizationFillet
Learn to design a spinning organization tray in Shapr3D with Mechanical Engineer Gabe Corbett. This project is ideal for organizing small parts, hardware, or art supplies, featuring a customizable, stackable tray design that spins independently when mounted on a pipe.
NESTING BOXES WITH SCALE, SHELL AND FILLET
ExtrudeShellMove/RotateVisualization
Join Gabe Corbett in this practical tutorial as he demonstrates how to design custom nesting organization boxes in Shapr3D. These versatile boxes are ideal for organizing small items while maintaining a compact, stackable design.
MODELING A QUAD BIK WITH EXTRUDE, MIRROR, AND SPLIT BODY
ExtrudeExportVisualizationFillet
Join industrial designer Sam Gwilt from Sam Does Design (youtube.com/@SamDoesDesign) as he demonstrates his efficient workflow in Shapr3D, focusing on quickly modeling, analyzing, and comparing design iterations. Follow Sam as he transitions from 2D sketches to a fully realized 3D model of an electric quad bike, showcasing how Shapr3D enhances the design process for rapid ideation and refinement.
USING SHAPR3D WITH RHINO 3D
HistoryExportVisualizationFillet
In this tutorial, Industrial Sam Gwilt from Sam Does Design (youtube.com/@SamDoesDesign) demonstrates how Shapr3D’s versatile exporting and importing features can integrate smoothly with other CAD software, enhancing workflows for collaborative projects and quick design edits across platforms.
DESIGN AN ORGANIC CHAIR WITH REVOLVE, SHELL, AND SWEEP
RevolveExtrudeShellFillet
Join expert 3D designer Claas Kuhnen in this tutorial as he demonstrates how to create an organic, complex chair design in Shapr3D.
ACTION CAMERA MOUNT, PART 4: CREATE FINGER JOINTS
Offset FaceExtrudeBooleanCopy
Andrew Camardella is back to guide you through the process of adding finger joints to the action camera mount, allowing for easy accessory attachments. This tutorial focuses on extending the mount’s functionality while keeping 3D printing considerations in mind.
ACTION CAMERA MOUNT, PART 3: ADD A MOUNTING BEEZEL
Offset FaceExtrudeBooleanMirror
Follow along as industrial designer Andrew Camardella enhances the action camera mount with a mounting bezel, improving its durability and 3D print quality. In this session, you’ll explore how to interface the mount with other components while optimizing the model for 3D printing.
USING SHAPR3D WITH SOLIDWORKS
SolidWorksImportExportVisualization
Follow along as mechanical engineer Gabe Corbett demonstrates how to import models between Shapr3D and SolidWorks, streamlining your workflow across different CAD systems.
MODERN SPEAKER DESIGN WITH PATTERNS, SHELL, AND MIRROR
MirrorFilletPatternShell
In this tutorial, industrial designer Daniel Brunsteiner walks you through the process of creating a modern speaker design using Shapr3D.
ACTION CAMERA MOUNT, PART 2: REFINE AND PRINT
ConstraintsExtrudeSubtractOffset Face
Industrial Designer Andrew Camardella is back to refine our previous action camera mount 3D model. In this session, we ensure compatibility with off-the-shelf components and optimize the model for 3D printing.
DOCK CLEAT PART 1: EXTRUDE, DRAFT, AND MIRROR
SketchExtrudePatternVisualization
Join mechanical engineer Gabe Corbett as he demonstrates how to create a dock cleat, showing valuable skills applicable to a variety of complex shapes and molded parts, such as drafting techniques, tapering methods, and the use of construction geometry.
PIPE FLANGE PART 2: MIRROR, PATTERN, AND IMPORT
MirrorImportPatternHistory
Following the primary pipe flange model, Mechanical Engineer Gabe Corbett demonstrates how to create a secondary flange and integrate bolts and nuts from external sources to save time while still ensuring precision. This tutorial covers essential Shapr3D tools and techniques, emphasizing efficiency and practical application.
PIPE FLANGE PART 1: REVOLVE AND CIRCULAR PATTERN
RevolvePatternChamferFillet
Join Mechanical Engineer Gabe Corbett as he guides you through the creation of a pipe flange using Shapr3D. Even if you're not specifically working on a pipe flange, the techniques and skills demonstrated can be applied to various similar projects such as gears and sprockets, mechanical couplings, and pump casings.
CUSTOM GLASSWARE WITH REVOLVE, SWEEP, AND PATTERN
SketchSweepProjectPattern
Learn how to model custom glassware with industrial designer, Daniel Brunsteiner. Watch as Daniel demonstrates step-by-step techniques, empowering you to create versatile and editable designs in Shapr3D.
ACTION CAMERA MOUNT, PART 1
SketchConstraintsProjectBoolean
Join Andrew Camardella, an industrial designer and adjunct faculty at DePaul University, as he explores advanced 3D sketching and modeling techniques to create a fully adjustable action camera mount.
CARABINER: FROM CONCEPT TO PRODUCTION
SketchExtrudeShellHistory
Follow along as Lautaro Lucero, an industrial designer and concept visualizer, models a carabiner from scratch in this detailed tutorial. Discover the essential steps of designing a product from initial sketches to the final manufactured model using Chamfer, Shell, Extrusion, Subtract, and other tools.
COFFEE SET: FROM CONCEPT TO PRODUCTION
TransformShellOffset FaceChamfer/Fillet
Join Lautaro Lucero an industrial designer and concept visualizer, as he creates a coffee set from scratch in this in-depth tutorial. Learn the key stages of product design, from the first sketches to the completed manufactured model.
FLOOR FAN WITH REVOLVE AND REPLACE FACE
RevolveProjectReplace FaceHistory
In this tutorial, industrial designer Class Kuhnen walks you through modeling a floor fan making use of quick feature adjustments with History-Based Parametric Modeling. Learn how to contour specific curved elements using core tools such as Revolve, Replace Face, and Project.
FAUCET WITH REVOLVE, UNION, AND CHAMFER
SketchConstraintsRevolveHistory
Industrial designer, Daniel Brunsteiner, walks you through modeling a faucet with a customizable sketch framework. Learn how to create layout sketches and apply necessary constraints to easily modify key elements of your model, allowing for a wide range of styles and variations.
STAIRCASE WITH EXTRUDE, LINEAR PATTERN, AND ROTATE AROUND AXIS
PatternExtrudeVisualizationHistory
Dive into this staircase modeling tutorial to get familiar with tools and techniques you can use in Shapr3D to build structures. This includes creating a layout sketch, patterning techniques, rotational geometry, reference sketches, editing your design based on the history, and applying wood materials in Visualization to achieve the ideal final model.
KETTLE DESIGN WITH EXTRUDE, SWEEP, AND SHELL
SketchConstruction PlaneOffset EdgeHistory
Here’s Daniel Brunsteiner, Industrial Designer, to help you build up your parametric modeling skills. Get comfortable with concepting this kettle and put your own spin on it.
PAN HANDLE DESIGN WITH LOFT, SWEEP, AND SUBTRACT
LoftSketchConstraintsHistory
Concept and finalize a frying pan with parametric modeling in Shapr3D. Claas Kuhnen demos importing and completing a model from sketching to building out bodies using G2 lofts.
SOAP BOTTLE WITH REVOLVE, SHELL, AND SPLIT BODY
LineSplineRevolveHistory
Get step-by-step instructions on creating this organically sculpted soap bottle body, adding threading, and prototyping a mechanical cap. Focus on key modeling tools including Revolve and Splines along using design history to prototype various stages of elements. Finally, add a product presentation for material studies, leveraging real-time editing capabilities to quickly finalize your model’s look.
SHAMPOO BOTTL WITH LOFT, SWEEP, AND SUBTRACT
SketchExtrudeBooleanHistory
Learn how to do concept design with parametric modeling in Shapr3D. Claas Kuhnen takes you from sketching through building out bodies to final product.
BRACKET MOUNT: MODELING BASICS IN SHAPR3D
Getting startedSketchTransformVisualization
This quick 15-minute tutorial will teach you all the basics of modeling in Shapr3D. Follow along for a fast-track of getting to your first model in minutes.
WATER BUCKET HANDLE WITH SPLIT BODY, SWEEP, AND MIRROR
SketchShellLoftHistory
Learn how to do concept designs working with sketches, tools including Loft (G1 and G2) and Shells, and design history to design this water bucket. You get practical step-by-step guidance and insider tips from industrial designer, Claas Kuhnen.
WATER BUCKET BASE WITH LOFT, SWEEP, AND SHELL
Parametric reference models
Explore models built in Shapr3D with full parametric history. Step through the design process, understand how each model was made, and make adjustments as you see fit.
Piston
Bracket mount
Pan handle
Night stand
Lamp
Lamp fixture
Graphics card fixture
Shampoo bottle
Cardan joint
Water bucket
Stool
Looking for something to practice with? Check out Shapr3D Sample Models to explore ready-made designs in Shapr3D.
The community
Connect with seasoned Shapr3D users as they share their expertise through videos, offering fresh ideas and practical solutions. Learn how the community is using Shapr3D to streamline workflows and overcome design challenges.
INTRODUCTION TO HISTORY-BASED PARAMETRIC MODELING
ConstraintsDimensionsDimensionsHistory
An introduction to the History feature by Industrial Designer, Sam.
17FT WHITE OAK MEDIA CENTER 3D MODEL
SketchConstraintsBooleanHistory
Follow along this walkthrough of a furniture model by Design Craft Workshop.
FURNITURE DESIGN USING PARAMETRIC MODELING
SketchConstraintsExtrudeHistory
Learn how to model furniture using parametric modeling with Bevelish Creations.
FURNITURE DESIGN FOR WOODWORKERS
SketchConstraintsExtrtudeHistory
Delve deeper into furniture design with these modeling tips from Bevelish Creations.
FURNITURE DESIGN WITH SOLID TOOLS
SketchConstraintsReplace FaceHistory
This tutorial from Bevelish Creations goes over how to create and edit sketches, and how to use solid tools to create 3D bodies, cut features, create chamfers, and roundovers.
PARAMETRIC FURNITURE MODELING WITH VARIABLES AND EXPRESSIONS
This tutorial from Bevelish Creations goes over how to to model a nightstand using parametric modeling with variables and expressions.
Tips & tricks
Discover short, practical videos offering tips and tricks to improve your day-to-day workflow and make the most of Shapr3D’s features.
CONTROL SURFACE CONTINUITY
SketchFilletLoftConstraints
Learn how to give your model surfaces physically smooth transitions by controlling surface continuity. Applying different options can have a big impact on your design.
DESIGN HISTORY
Follow along with this walkthrough of a furniture model by Design Craft Workshop.
0 out of 0 found this helpful
