Export custom materials for Shapr3D Visualization
Shapr3D Visualization supports importing custom materials through the .GLB file format. This makes it possible to bring in materials created in external rendering or material-authoring applications and use them directly in Shapr3D.
A GLB file is based on the glTF (GL Transmission Format) standard and is designed for exchanging 3D assets between applications. It can bundle material definitions, textures, and shading information into a single file, which makes it a practical format for transferring custom materials into Shapr3D.
Many professional visualization tools support exporting materials as GLB, allowing you to build custom material libraries outside of Shapr3D and then import them for realistic rendering and presentation.
This article outlines common workflows for exporting materials from popular rendering tools and preparing them for import into Shapr3D Visualization.
General workflow for exporting custom materials
Most rendering and material-authoring tools don’t export materials as standalone files. Instead, materials are included in a .GLB export by applying them to one or more bodies first.
  1. Create or edit your material in a supported third-party application such as Blender, Substance, or KeyShot.
  2. Apply the material to a body in the scene. If you want to export multiple materials, apply each one to a separate body.
  3. Export the textured body or bodies as a .GLB file. The exported GLB file will carry the material definitions and textures.
  4. Import the GLB file into Shapr3D Visualization.
For detailed platform-specific export steps, refer to the official documentation of your rendering software.
If your rendering tool doesn’t support direct GLB export, you can often use Blender as a conversion step by exporting an intermediate file format (such as FBX) and then exporting from Blender as GLB.
Workflow by application
Blender
Blender is one of the most common tools for preparing GLB-based material libraries. You can create materials directly in Blender or use it to convert materials from other software into the GLB format.
Substance (Adobe)
Substance tools can generate advanced PBR material sets that can be exported and packaged into GLB through compatible workflows.
KeyShot
KeyShot materials can be transferred into GLB workflows depending on your export setup and supported extensions.
Autodesk VRED
VRED workflows depend on the version you are using:
VRED 2024 and newer
  1. Apply the materials you want to import to a body or multiple bodies within your VRED scene.
    Note: To export multiple materials, apply each one to a separate body.
  2. Export the material as a GLB file from VRED.
  3. Import the GLB file into Shapr3D Visualization.
VRED versions before 2024
  1. Export an FBX file from VRED.
  2. Import the FBX file into Blender.
  3. Export from Blender as .GLB.
For more details, refer to Autodesk’s documentation: Best Practices for Sharing and Embedding USDz and GLB Files
Generate a GLB material file using AI tools
If you already have an image reference (such as a wall texture or fabric pattern), you can also use AI-based tools to help generate a .GLB file that contains a ready-to-import material. This workflow can be useful for quickly creating custom materials when you don’t have an existing rendering pipeline.
  1. Upload your reference image to an AI tool such as ChatGPT that supports 3D or material export workflows.
  2. Use a prompt requesting a GLB file that includes a material with embedded textures.
    • For example: Generate a .glb file that contains a material with 2K textures using this image as a reference.
  3. Download the generated GLB file.
Use external material libraries
If you don’t already have a material library, you can also find free material libraries online from sources such as Poly Haven. If a material isn’t available in .GLB format you can:
  1. Download a Blender-compatible version.
  2. Open the file in Blender.
  3. Export the file as a .GLB file.
To learn how to import and apply custom materials, visit Visualization.
6 out of 6 found this helpful
