Introducing Shapr3D Basics
3%
Learn sketching, modeling, visualizing, and documenting motorcycle parts for hands-on practice. Discover the ins and outs of Shapr3D, from setting up your modeling space to leveraging its Selection-Based Interface and expansive toolbox.
Hi, I'm Matt Lombard. I've worked as a mechanical engineer, doing everything from plastic part design to CAD applications engineer, and currently working as a design consultant. These videos will help you take the ideas that are in your head and form 3D digital data that you can use to communicate with others and 3D print your designs into reality.
Motorcycle
Motorcycle cover
Piston
Piston rod
Rod clamp
4 motorcycle wheel
Frame
Block casting
593 out of 996 found this helpful
