Choose hardware and input devices
9%
← Back: Get started: A Shapr3D overviewNext: Grid and sketch settings →
Run Shapr3D on your existing devices and work with the input device of your choice. Explore a variety of setups to fit your workflow — no specialized hardware or equipment needed.
Shapr3D works on a range of portable devices. Everything from Windows tablets and convertibles to a regular iPad. You can also use Shapr3D on touchscreen laptops using both Apple and Microsoft operating systems. You can use a Wacom tablet with any of these devices, along with just the simple trackpad.
00:25
My preferred setup is to use a keyboard and mouse on a Windows laptop with a docking station. And when I'm on the road, I use my Microsoft Surface. You don't need highly sophisticated equipment and they both run shape perfectly. If you're already accustomed to using a Wacom tablet, then you're ahead of the game and you'll find it easy to adapt to the same interface on Shapr3D.
00:55
with your left hand on the buttons and your right hand on the stylus is a very effective and efficient way to use the software.
Motorcycle
Motorcycle cover
Piston
Piston rod
Rod clamp
4 motorcycle wheel
Frame
Block casting
60 out of 106 found this helpful
