Getting started as a contributor in a Shapr3D team
If you’ve received an invitation to join a Shapr3D team as a contributor, here’s how to get started.
Accept your invitation
You’ll receive an invitation email from the team owner. To accept the invite:
  1. Open the invitation email.
  2. Select Accept invite.
  3. Sign up with the email address the invite was sent to.
  4. If you already have a Shapr3D account, just log in with your credentials.
Important
Contributor access is only available to company email addresses. Invitations sent to personal emails (such as @gmail.com, @icloud.com) or educational addresses (such as .edu) will not work.
Download and install Shapr3D
After signing up or logging in, install Shapr3D on your preferred device. To learn how, visit Download Shapr3D.
Access a team you joined
When you open Shapr3D, the Dashboard opens in your personal team by default. If you’ve joined another team, use the team switcher to access that team’s shared space.
As a contributor or editor, you can view and collaborate on projects in any shared space you’re part of. Each team has its own spaces for shared projects and personal drafts, and access depends on your role.
To learn more, visit Shapr3D Dashboard and Manage your personal account and team settings.
What you can and can’t do as a contributor
As a contributor, you can:
  • Access the full feature set of Shapr3D (excluding Drafts)
  • Open and work on projects in the shared space
  • Collaborate with other team members
As a contributor, you can’t:
  • Create new projects
  • Export projects or drawings
  • Access Drafts
Contributor access is only available for Shapr3D version 5.831 and later. If you don’t see the team or encounter access issues, make sure your Shapr3D version is up-to-date.
To get started with Shapr3D, check out our Introducing Shapr3D basics tutorial series.
0 out of 1 found this helpful
