Learn how to customize the appearance of your model using Display Modes, switch between shading styles, analyze surface and curve geometry, and adjust the visibility of edges and decals.
What are Display Modes?
You can use the Display Modes menu to control how geometry is visually presented in the modeling space without modifying the underlying geometry.
Display Modes lets you:
- Switch between shading styles to inspect your model.
- Evaluate surface continuity and curvature using surface analysis.
- Analyze curve smoothness and curvature using curvature combs.
- Control the visibility of body edges, hidden edges, and decals.
How to use Display Modes
To use the Display Modes menu:
- Select Display Modes from the toolbar to open the menu.
- Choose a shader, use surface analysis or curvature comb analysis, or toggle additional options to update how your model appears in the modeling space.
- To check the active shader at a glance, look at the label below Display Modes in the menu.
Shaders
Switch between shading styles to adjust how geometry and edges appear in the modeling space.
- Wireframe – Displays only the edges and outlines of your model, with no surface fill.
- X-Ray – Displays your model with semi-transparent surfaces, allowing you to see through bodies to view internal details, hidden edges, or overlapping geometry.
- Shaded – Displays solid shaded bodies. This is the default mode.
- Visualized – Displays your model with physically based materials in a realistic environment.
Surface Analysis
Use surface visualization tools to evaluate model continuity and curvature. These tools help you identify surface smoothness and transitions in complex shapes.
Zebra – Applies zebra striping to evaluate surface continuity (G0, G1, G2).
- Direction: Choose between Horizontal or Vertical stripes.
- Scale: Adjust the sensitivity of the curvature analysis display.
Curvature Map – Applies a color-coded gradient to visualize curvature changes across the surface.
Curvature Comb Analysis
Use curvature combs to visualize how curvature changes along sketch curves and model edges. Curvature combs display a series of lines extending from the selected geometry, helping you evaluate curve smoothness, identify abrupt changes in curvature, and inspect transitions between curves.
Use curvature combs
To display curvature combs:
- Open Display Modes from the toolbar.
- Under Curvature Comb Analysis, turn on Curvature Combs.
- Select the curve or edge you want to analyze.
- Adjust the following settings as needed:
- Scale – Adjust the displayed length of the curvature indicators to make curvature variations easier to inspect.
- Density – Adjust the number of curvature indicators displayed along the selected geometry.
Interpret curvature combs
The length and direction of the curvature indicators help you understand how a curve bends at different points along its length.
- Longer indicators: Represent areas of higher curvature, where the curve bends more sharply.
- Shorter indicators: Represent areas of lower curvature, where the curve is flatter.
- Gradual changes in indicator length: Indicate smooth changes in curvature.
- Abrupt changes in indicator length: Can indicate sudden changes in curvature that may require further inspection.
- Changes in indicator direction: Help identify where the curve changes its bending direction.
Curvature combs are particularly useful when refining splines, evaluating connections between curves, or preparing curves for subsequent modeling operations.
Note: Adjusting Scale and Density only changes how curvature combs are displayed and does not modify the underlying geometry.
Options
Toggle additional visibility settings to refine how your model appears in the modeling space.
- Show Edges – Displays the edges of bodies in the modeling space.
- Show Hidden Edges – Displays edges that are hidden behind the model's own surfaces, making it easier to see the full geometry of a body without rotating the view.
- Show Decals – Shows or hides decals applied to your model surfaces in Visualization.
