Learn how to import and export native Shapr3D (.shapr) files to transfer projects between devices and preserve your Shapr3D project data.
What is a SHAPR file?
SHAPR (.shapr) is the native project file format of Shapr3D. Unlike standard CAD exchange formats that primarily transfer geometry, SHAPR files are designed to preserve your Shapr3D project data.
Use SHAPR files to transfer projects between devices, create local copies of your designs, or share projects with other Shapr3D users.
Import SHAPR files into Shapr3D
Import a .shapr file to open an existing Shapr3D project or bring its contents into your current design.
When importing a Shapr3D project into an existing design, the imported project's design history is preserved rather than combined into a single import step.
For step-by-step instructions on importing projects and files, visit How to import files into Shapr3D.
Export SHAPR files from Shapr3D
Export your project in .shapr format to save a native Shapr3D file that you can import into Shapr3D later.
SHAPR exports preserve the complete project rather than only isolated parts. SHAPR files always export the complete project, including parts that are currently hidden or isolated.
For step-by-step instructions on exporting projects, visit How to export files from Shapr3D.
Considerations when using SHAPR files
- Native compatibility: SHAPR files are intended for use in Shapr3D. To work with other CAD applications, export to a compatible exchange format such as STEP or Parasolid.
- Project history: SHAPR files preserve Shapr3D design history, unlike formats that import geometry as a single step.
- Project transfer: You can use SHAPR files to transfer projects between supported Shapr3D platforms, including when Sync is disabled.
