Using sketch planes
To sketch in 2D, you must define a sketch plane icon-base-plane.png where you want to create your sketch. You can define a sketch plane in the following ways:
How to start a sketch in different planes
To start sketching on a plane:
  1. From the main menu, select Sketch.
  2. From the three small rectangles that appear near the origin, click on the rectangle corresponding to the plane you’d like to sketch on.
To select a sketch tool right away:
  1. From the sketch menu, select a sketch tool.
    For other methods of accessing tools, visit Accessing tools.
  2. From the three small rectangles that appear near the origin, drag your pointer to hover over the rectangle corresponding to the plane you’d like to sketch.
  3. Press the Space bar.
To start sketching on a different plane:
  1. Drag your pointer to hover over a planar face or construction plane.
    Note: This is also possible with your pen if the platform supports hovering with the pen.
  2. Press the Space bar.
If you accidentally rotate your view while in sketch mode and want to continue sketching in 2D with a normal view on your previously selected plane, select Normal to Sketch at the top.
How Shapr3D organizes your sketches
Sketches you create are automatically added to the Items Manager and the History sidebar as new items. If you continue sketching on a plane immediately after creating a sketch on the same plane, Shapr3D will edit the previous sketch. In every other case, a new sketch is created.
Note: For Shapr3D versions earlier than 5.590, sketches are organized by planes, so adding a new sketch item to a plane you previously sketched on automatically adds it to the existing Sketch plane item in the Items Manager.
36 out of 62 found this helpful
