Supported import and export file formats in Shapr3D
Find out which file formats Shapr3D supports for importing and exporting, including CAD models, sketches, drawings, images, and mesh files.
Feature availability
Available file formats and project limits may vary depending on your Shapr3D plan. For details, visit the Pricing page.
Supported import formats
Import sketches, 3D models, and images from other applications into Shapr3D. The supported geometry and available functionality depend on the file format.
2D sketches
Import supported 2D geometry as sketches for use in your designs.
  • DWG
  • DXF
  • SVG
3D models
Import supported CAD models and mesh geometry.
  • SHAPR (.shapr)
  • Parasolid (.x_t, .x_b)
  • STEP (.step, .stp)
  • IGES (.iges, .igs)
  • SolidWorks part (.sldprt)
  • SolidWorks assembly (.sldasm)
  • STL (.stl)
  • 3MF (.3mf)
Images
Import images to use as visual references while modeling.
  • PNG
  • JPG
  • PDF (2D, single page or first page only)
  • TIFF
  • BMP
  • ICO
  • RAW
  • GIF (non-animated)
Advanced CAD formats
Shapr3D Enterprise supports importing additional native CAD formats. For more information, visit our articles about working with other CAD applications.
  Application or format   Supported file extensions
  NX   .prt (part and assembly)
  CATIA   .catpart (part), .catproduct (assembly)
  Creo   .prt (part), .asm (assembly)
  Solid Edge   .par (part), .asm and .psm (assembly)
  JT   .jt (part and assembly)
Supported export formats
Export your Shapr3D designs for use in CAD applications, manufacturing, 3D printing, visualization, and collaboration.
2D formats
Export sketches, drawings, and images in supported formats.
  Format   Export content
  DWG   Sketches and 2D drawings
  DXF   Sketches and 2D drawings
  SVG   Sketches
  PDF   2D drawings
  JPEG   Images
  PNG   Images
3D formats
Export 3D models in supported CAD, mesh, and visualization formats.
  Format   Typical use
  SHAPR (.shapr)   Native Shapr3D projects
  Parasolid (.x_t, .x_b)   CAD model exchange
  STEP (.step, .stp)   CAD model exchange
  IGES (.iges, .igs)   CAD model exchange
  STL (.stl)   Mesh export and 3D printing
  3MF (.3mf)   Mesh export with supported color information
  OBJ (.obj)   Mesh export with colors
  GLB (.glb)   Visualization and augmented reality
  USDZ (.usdz)   Visualization and augmented reality
Shapr3D Enterprise also supports exporting JT (.jt) files for CAD data exchange.
Other sharing options
You can also share designs without exporting a separate file.
233 out of 325 found this helpful
