Items and Exporting the models
Tutorial series: Concepting fundamentals
100%
← Back: VisualizationNext: Design for manufacturing course →
Create and organize folders for your laundry detergent model’s different concepts and sketches, creating a clean space to view and decide on iterations of your concept. Select from the wide range of file options to export and share your model for viewing.
So let's jump back into modeling, go to items, and let's create two folders. The first folder will be concept one and the second one, concept two. We have our pattern folder, which we don't need anymore. We have our different bodies. So we have body one, which is concept one. We have our body two, which is also the corresponding lid. So let's move that into concept one as well. And then we have.
00:29
Body 2 and 1 for the second concept. So we'll move that here as well. And for the sketches, let's create another folder, rename that to sketches and select all these sketches and move those into here. We can also move the underlay image into the sketches folder just to tidy it up. And now you can easily switch between those two concepts.
00:55
You could also just go back and move the second concept here onto the center point and switch back and forth and see which one you like best. Or you could hide one and then go to share and export the project for 3D printing or as a step to share it with your client. Make sure when exporting that the include hidden items is checked off. So you always only export the one that you see.
01:23
Alright, this was it for our tutorial series on conceptual design in Shapr3D. I hope you learned something new today and see you next time.
17 out of 22 found this helpful
