Shapr3D uses several third-party libraries, repositories, and other similar software packages. Thank you to the owners and contributors listed below.
3Dconnexion
3Dconnexion provides the software that allows you to use the SpaceMouse with Shapr3D for Mac. For more information on 3Dconnexion’s software or hardware, go to the 3Dconnexion website . If you want to set up your SpaceMouse for Shapr3D, follow the steps here .
abseil
Apache License Version 2.0, January 2004 https://www.apache.org/licenses/
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions. "License" shall mean the terms and conditions for use, reproduction, and
distribution as defined by Sections 1 through 9 of this document. "Licensor" shall mean the
copyright owner or entity authorized by the copyright owner that is granting the License. "Legal
Entity" shall mean the union of the acting entity and all other entities that control, are
controlled by, or are under common control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the direction or management of such
entity, whether by contract or otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity. "You" (or "Your") shall mean an
individual or Legal Entity exercising permissions granted by this License. "Source" form shall mean
the preferred form for making modifications, including but not limited to software source code,
documentation source, and configuration files. "Object" form shall mean any form resulting from
mechanical transformation or translation of a Source form, including but not limited to compiled
object code, generated documentation, and conversions to other media types. "Work" shall mean the
work of authorship, whether in Source or Object form, made available under the License, as indicated
by a copyright notice that is included in or attached to the work (an example is provided in the
Appendix below). "Derivative Works" shall mean any work, whether in Source or Object form, that is
based on (or derived from) the Work and for which the editorial revisions, annotations,
elaborations, or other modifications represent, as a whole, an original work of authorship. For the
purposes of this License, Derivative Works shall not include works that remain separable from, or
merely link (or bind by name) to the interfaces of, the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including the original version of the Work and any
modifications or additions to that Work or Derivative Works thereof, that is intentionally submitted
to Licensor for inclusion in the Work by the copyright owner or by an individual or Legal Entity
authorized to submit on behalf of the copyright owner. For the purposes of this definition,
"submitted" means any form of electronic, verbal, or written communication sent to the Licensor or
its representatives, including but not limited to communication on electronic mailing lists, source
code control systems, and issue tracking systems that are managed by, or on behalf of, the Licensor
for the purpose of discussing and improving the Work, but excluding communication that is
conspicuously marked or otherwise designated in writing by the copyright owner as "Not a
Contribution." "Contributor" shall mean Licensor and any individual or Legal Entity on behalf of
whom a Contribution has been received by Licensor and subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of this License, each Contributor
hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of, publicly display, publicly perform,
sublicense, and distribute the Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of this License, each Contributor
(except as stated in this section) patent license to make, have made, use, offer to sell, sell,
import, and otherwise transfer the Work, where such license applies only to those patent claims
licensable by such Contributor that are necessarily infringed by their Contribution(s) alone or by
combination of their Contribution(s) with the Work to which such Contribution(s) was submitted. If
You institute patent litigation against any entity (including a cross-claim or counterclaim in a
lawsuit) alleging that the Work or a Contribution incorporated within the Work constitutes direct or
contributory patent infringement, then any patent licenses granted to You under this License for
that Work shall terminate as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the Work or Derivative Works thereof
in any medium, with or without modifications, and in Source or Object form, provided that You meet
the following conditions: (a) You must give any other recipients of the Work or Derivative Works a
copy of this License; and (b) You must cause any modified files to carry prominent notices stating
that You changed the files; and (c) You must retain, in the Source form of any Derivative Works that
You distribute, all copyright, patent, trademark, and attribution notices from the Source form of
the Work, excluding those notices that do not pertain to any part of the Derivative Works; and (d)
If the Work includes a "NOTICE" text file as part of its distribution, then any Derivative Works
that You distribute must include a readable copy of the attribution notices contained within such
NOTICE file, excluding those notices that do not pertain to any part of the Derivative Works, in at
least one of the following places: within a NOTICE text file distributed as part of the Derivative
Works; within the Source form or documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and wherever such third-party notices
normally appear. The contents of the NOTICE file are for informational purposes only and do not
modify the License. You may add Your own attribution notices within Derivative Works that You
distribute, alongside or as an addendum to the NOTICE text from the Work, provided that such
additional attribution notices cannot be construed as modifying the License. You may add Your own
copyright statement to Your modifications and may provide additional or different license terms and
conditions for use, reproduction, or distribution of Your modifications, or for any such Derivative
Works as a whole, provided Your use, reproduction, and distribution of the Work otherwise complies
with the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise, any Contribution
intentionally submitted for inclusion in the Work by You to the Licensor shall be under the terms
and conditions of this License, without any additional terms or conditions. Notwithstanding the
above, nothing herein shall supersede or modify the terms of any separate license agreement you may
have executed with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade names, trademarks, service
marks, or product names of the Licensor, except as required for reasonable and customary use in
describing the origin of the Work and reproducing the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or agreed to in writing, Licensor
provides the Work (and each Contributor provides its Contributions) on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied, including, without limitation, any
warranties or conditions of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A PARTICULAR
PURPOSE. You are solely responsible for determining the appropriateness of using or redistributing
the Work and assume any risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory, whether in tort (including
negligence), contract, or otherwise, unless required by applicable law (such as deliberate and
grossly negligent acts) or agreed to in writing, shall any Contributor be liable to You for damages,
including any direct, indirect, special, incidental, or consequential damages of any character
arising as a result of this License or out of the use or inability to use the Work (including but
not limited to damages for loss of goodwill, work stoppage, computer failure or malfunction, or any
and all other commercial damages or losses), even if such Contributor has been advised of the
possibility of such damages.
9. Accepting Warranty or Additional Liability. While redistributing the Work or Derivative Works
thereof, You may choose to offer, and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this License. However, in accepting
such obligations, You may act only on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify, defend, and hold each Contributor
harmless for any liability incurred by, or claims asserted against, such Contributor by reason of
your accepting any such warranty or additional liability.
END OF TERMS AND CONDITIONS
BLAKE3
Apache License Version 2.0, January 2004 http://www.apache.org/licenses/
END OF TERMS AND CONDITIONS APPENDIX: How to apply the Apache License to your work. To apply the
Apache License to your work, attach the following boilerplate notice, with the fields enclosed by
brackets "[]" replaced with your own identifying information. (Don't include the brackets!) The text
should be enclosed in the appropriate comment syntax for the file format. We also recommend that a
file or class name and description of purpose be included on the same "printed page" as the
copyright notice for easier identification within third-party archives. Copyright 2019 Jack O'Connor
and Samuel Neves
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in
compliance with the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0 Unless required by applicable law or agreed to in
writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific
language governing permissions and limitations under the License.
Cap'nProto
Copyright (c) 2013-2017 Sandstorm Development Group, Inc.; Cloudflare, Inc.; and other contributors.
Each commit is copyright by its respective author or author's employer.
Licensed under the
MIT License:
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and
associated documentation files (the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute,
sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions: The above copyright notice and this
permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT
NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
CC-CEDICT
The Mandarin dictionary files in this folder are based on CC-CEDICT, a community-maintained free Chinese-English dictionary. CC-CEDICT is a continuation of the CEDICT project started by Paul Denisowski in 1997. The aim of CC-CEDICT is to provide a complete downloadable Chinese to English dictionary with pronunciation in pinyin for the Chinese characters.
# CC-CEDICT
# Community maintained free Chinese-English dictionary.
# Published by MDBG
# License:
# Creative Commons Attribution-ShareAlike 4.0 International License
# https://creativecommons.org/licenses/by-sa/4.0/
# Referenced works:
# CEDICT - Copyright (C) 1997, 1998 Paul Andrew Denisowski
# CC-CEDICT can be downloaded from:
# https://www.mdbg.net/chinese/dictionary?page=cc-cedict
# Additions and corrections can be sent through:
# https://cc-cedict.org/editor/editor.php
# For more information about CC-CEDICT see:
# https://cc-cedict.org/wiki/
#! version=1
#! subversion=0
#! format=ts
#! charset=UTF-8
#! entries=121646
#! publisher=MDBG
#! license=https://creativecommons.org/licenses/by-sa/4.0/
#! date=2023-04-16T01:18:48Z
#! time=1681607928
The dictionary files were converted to a different file format by the cpp-pinyin project (https://github.com/wolfgitpr/cpp-pinyin). Shapr3D uses them unmodified.
cgltf
Copyright (c) 2018-2021 Johannes Kuhlmann
NONINFRINGEMENT.
cpp-pinyin
Apache License
1. Definitions.
and distribution as defined by Sections 1 through 9 of this document.
"Licensor" shall mean the copyright owner or entity authorized by
"Legal Entity" shall mean the union of the acting entity and all
other entities that control, are controlled by, or are under common
direction or management of such entity, whether by contract or
"You" (or "Your") shall mean an individual or Legal Entity
"Source" form shall mean the preferred form for making modifications,
including but not limited to software source code, documentation
"Object" form shall mean any form resulting from mechanical
not limited to compiled object code, generated documentation,
"Work" shall mean the work of authorship, whether in Source or
Object form, made available under the License, as indicated by a
(an example is provided in the Appendix below).
form, that is based on (or derived from) the Work and for which the
editorial revisions, annotations, elaborations, or other modifications
represent, as a whole, an original work of authorship. For the purposes
separable from, or merely link (or bind by name) to the interfaces of,
the original version of the Work and any modifications or additions
submitted to Licensor for inclusion in the Work by the copyright owner
or by an individual or Legal Entity authorized to submit on behalf of
the copyright owner. For the purposes of this definition, "submitted"
to the Licensor or its representatives, including but not limited to
communication on electronic mailing lists, source code control systems,
Licensor for the purpose of discussing and improving the Work, but
excluding communication that is conspicuously marked or otherwise
designated in writing by the copyright owner as "Not a Contribution."
on behalf of whom a Contribution has been received by Licensor and
this License, each Contributor hereby grants to You a perpetual,
publicly display, publicly perform, sublicense, and distribute the
use, offer to sell, sell, import, and otherwise transfer the Work,
where such license applies only to those patent claims licensable
Contribution(s) alone or by combination of their Contribution(s)
with the Work to which such Contribution(s) was submitted. If You
cross-claim or counterclaim in a lawsuit) alleging that the Work
or contributory patent infringement, then any patent licenses
granted to You under this License for that Work shall terminate
Work or Derivative Works thereof in any medium, with or without
meet the following conditions:
Derivative Works a copy of this License; and
stating that You changed the files; and
that You distribute, all copyright, patent, trademark, and
attribution notices from the Source form of the Work,
(d) If the Work includes a "NOTICE" text file as part of its
distribution, then any Derivative Works that You distribute must
within such NOTICE file, excluding those notices that do not
pertain to any part of the Derivative Works, in at least one
as part of the Derivative Works; within the Source form or
wherever such third-party notices normally appear. The contents
do not modify the License. You may add Your own attribution
notices within Derivative Works that You distribute, alongside
that such additional attribution notices cannot be construed
You may add Your own copyright statement to Your modifications and
may provide additional or different license terms and conditions
for any such Derivative Works as a whole, provided Your use,
reproduction, and distribution of the Work otherwise complies with
any Contribution intentionally submitted for inclusion in the Work
by You to the Licensor shall be under the terms and conditions of
Notwithstanding the above, nothing herein shall supersede or modify
the terms of any separate license agreement you may have executed
names, trademarks, service marks, or product names of the Licensor,
except as required for reasonable and customary use in describing the
agreed to in writing, Licensor provides the Work (and each
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
implied, including, without limitation, any warranties or conditions
PARTICULAR PURPOSE. You are solely responsible for determining the
appropriateness of using or redistributing the Work and assume any
whether in tort (including negligence), contract, or otherwise,
unless required by applicable law (such as deliberate and grossly
liable to You for damages, including any direct, indirect, special,
incidental, or consequential damages of any character arising as a
Work (including but not limited to damages for loss of goodwill,
work stoppage, computer failure or malfunction, or any and all
has been advised of the possibility of such damages.
the Work or Derivative Works thereof, You may choose to offer,
License. However, in accepting such obligations, You may act only
defend, and hold each Contributor harmless for any liability
of your accepting any such warranty or additional liability.
To apply the Apache License to your work, attach the following
boilerplate notice, with the fields enclosed by brackets "[]"
the brackets!) The text should be enclosed in the appropriate
same "printed page" as the copyright notice for easier
Copyright (C) 2023-2024 Stdware Collections (https://www.github.com/stdware)
Copyright (C) 2021-2023 wangwenx190 (Yuhang Zhao)
you may not use this file except in compliance with the License.
Unless required by applicable law or agreed to in writing, software
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
D3D12 Memory Allocator
Copyright (c) 2019-2026 Advanced Micro Devices, Inc. All rights reserved.
NONINFRINGEMENT.
Dear ImGui
The
MIT License (MIT) Copyright (c) 2014-2021 Omar Cornut
NONINFRINGEMENT.
Draco 3D Graphics Compression
copyright notice for easier identification within third-party archives. Copyright [yyyy] [name of
copyright owner]
-------------------------------------------------------------------------------- Files:
docs/assets/js/ASCIIMathML.js Copyright (c) 2014 Peter Jipsen and other ASCIIMathML.js contributors
NONINFRINGEMENT.
docs/assets/css/pygments/* This is free and unencumbered software released into the public domain.
Anyone is free to copy, modify, publish, use, compile, sell, or distribute this software, either in
source code form or as a compiled binary, for any purpose, commercial or non-commercial, and by any
means. In jurisdictions that recognize copyright laws, the author or authors of this software
dedicate any and all copyright interest in the software to the public domain. We make this
dedication for the benefit of the public at large and to the detriment of our heirs and successors.
We intend this dedication to be an overt act of relinquishment in perpetuity of all present and
future rights to this software under copyright law.
NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR
THE USE OR OTHER DEALINGS IN THE SOFTWARE. For more information, please refer to
<http://unlicense.org>
Eigen
Mozilla Public License Version 2.0
1. Definitions 1.1. “Contributor” means each individual or legal entity that creates, contributes to
the creation of, or owns Covered Software. 1.2. “Contributor Version” means the combination of the
Contributions of others (if any) used by a Contributor and that particular Contributor’s
Contribution. 1.3. “Contribution” means Covered Software of a particular Contributor. 1.4. “Covered
Software” means Source Code Form to which the initial Contributor has attached the notice in Exhibit
A, the Executable Form of such Source Code Form, and Modifications of such Source Code Form, in each
case including portions thereof. 1.5. “Incompatible With Secondary Licenses” means that the initial
Contributor has attached the notice described in Exhibit B to the Covered Software; or that the
Covered Software was made available under the terms of version 1.1 or earlier of the License, but
not also under the terms of a Secondary License. 1.6. “Executable Form” means any form of the work
other than Source Code Form. 1.7. “Larger Work” means a work that combines Covered Software with
other material, in a separate file or files, that is not Covered Software. 1.8. “License” means this
document. 1.9. “Licensable” means having the right to grant, to the maximum extent possible, whether
at the time of the initial grant or subsequently, any and all of the rights conveyed by this
License. 1.10. “Modifications” means any of the following: any file in Source Code Form that results
from an addition to, deletion from, or modification of the contents of Covered Software; or any new
file in Source Code Form that contains any Covered Software. 1.11. “Patent Claims” of a Contributor
means any patent claim(s), including without limitation, method, process, and apparatus claims, in
any patent Licensable by such Contributor that would be infringed, but for the grant of the License,
by the making, using, selling, offering for sale, having made, import, or transfer of either its
Contributions or its Contributor Version. 1.12. “Secondary License” means either the GNU General
Public License, Version 2.0, the GNU Lesser General Public License, Version 2.1, the GNU Affero
General Public License, Version 3.0, or any later versions of those licenses. 1.13. “Source Code
Form” means the form of the work preferred for making modifications. 1.14. “You” (or “Your”) means
an individual or a legal entity exercising rights under this License. For legal entities, “You”
includes any entity that controls, is controlled by, or is under common control with You. For
purposes of this definition, “control” means (a) the power, direct or indirect, to cause the
direction or management of such entity, whether by contract or otherwise, or (b) ownership of more
than fifty percent (50%) of the outstanding shares or beneficial ownership of such entity. 2.
License Grants and Conditions 2.1. Grants Each Contributor hereby grants You a world-wide,
royalty-free, non-exclusive license: under intellectual property rights (other than patent or
trademark) Licensable by such Contributor to use, reproduce, make available, modify, display,
perform, distribute, and otherwise exploit its Contributions, either on an unmodified basis, with
Modifications, or as part of a Larger Work; and under Patent Claims of such Contributor to make,
use, sell, offer for sale, have made, import, and otherwise transfer either its Contributions or its
Contributor Version. 2.2. Effective Date The licenses granted in Section 2.1 with respect to any
Contribution become effective for each Contribution on the date the Contributor first distributes
such Contribution. 2.3. Limitations on Grant Scope The licenses granted in this Section 2 are the
only rights granted under this License. No additional rights or licenses will be implied from the
distribution or licensing of Covered Software under this License. Notwithstanding Section 2.1(b)
above, no patent license is granted by a Contributor: for any code that a Contributor has removed
from Covered Software; or for infringements caused by: (i) Your and any other third party’s
modifications of Covered Software, or (ii) the combination of its Contributions with other software
(except as part of its Contributor Version); or under Patent Claims infringed by Covered Software in
the absence of its Contributions. This License does not grant any rights in the trademarks, service
marks, or logos of any Contributor (except as may be necessary to comply with the notice
requirements in Section 3.4). 2.4. Subsequent Licenses No Contributor makes additional grants as a
result of Your choice to distribute the Covered Software under a subsequent version of this License
(see Section 10.2) or under the terms of a Secondary License (if permitted under the terms of
Section 3.3). 2.5. Representation Each Contributor represents that the Contributor believes its
Contributions are its original creation(s) or it has sufficient rights to grant the rights to its
Contributions conveyed by this License. 2.6. Fair Use This License is not intended to limit any
rights You have under applicable copyright doctrines of fair use, fair dealing, or other
equivalents. 2.7. Conditions Sections 3.1, 3.2, 3.3, and 3.4 are conditions of the licenses granted
in Section 2.1. 3. Responsibilities 3.1. Distribution of Source Form All distribution of Covered
Software in Source Code Form, including any Modifications that You create or to which You
contribute, must be under the terms of this License. You must inform recipients that the Source Code
Form of the Covered Software is governed by the terms of this License, and how they can obtain a
copy of this License. You may not attempt to alter or restrict the recipients’ rights in the Source
Code Form. 3.2. Distribution of Executable Form If You distribute Covered Software in Executable
Form then: such Covered Software must also be made available in Source Code Form, as described in
Section 3.1, and You must inform recipients of the Executable Form how they can obtain a copy of
such Source Code Form by reasonable means in a timely manner, at a charge no more than the cost of
distribution to the recipient; and You may distribute such Executable Form under the terms of this
License, or sublicense it under different terms, provided that the license for the Executable Form
does not attempt to limit or alter the recipients’ rights in the Source Code Form under this
License. 3.3. Distribution of a Larger Work You may create and distribute a Larger Work under terms
of Your choice, provided that You also comply with the requirements of this License for the Covered
Software. If the Larger Work is a combination of Covered Software with a work governed by one or
more Secondary Licenses, and the Covered Software is not Incompatible With Secondary Licenses, this
License permits You to additionally distribute such Covered Software under the terms of such
Secondary License(s), so that the recipient of the Larger Work may, at their option, further
distribute the Covered Software under the terms of either this License or such Secondary License(s).
3.4. Notices You may not remove or alter the substance of any license notices (including copyright
notices, patent notices, disclaimers of warranty, or limitations of liability) contained within the
Source Code Form of the Covered Software, except that You may alter any license notices to the
extent required to remedy known factual inaccuracies. 3.5. Application of Additional Terms You may
choose to offer, and to charge a fee for, warranty, support, indemnity or liability obligations to
one or more recipients of Covered Software. However, You may do so only on Your own behalf, and not
on behalf of any Contributor. You must make it absolutely clear that any such warranty, support,
indemnity, or liability obligation is offered by You alone, and You hereby agree to indemnify every
Contributor for any liability incurred by such Contributor as a result of warranty, support,
indemnity or liability terms You offer. You may include additional disclaimers of warranty and
limitations of liability specific to any jurisdiction. 4. Inability to Comply Due to Statute or
Regulation If it is impossible for You to comply with any of the terms of this License with respect
to some or all of the Covered Software due to statute, judicial order, or regulation then You must:
(a) comply with the terms of this License to the maximum extent possible; and (b) describe the
limitations and the code they affect. Such description must be placed in a text file included with
all distributions of the Covered Software under this License. Except to the extent prohibited by
statute or regulation, such description must be sufficiently detailed for a recipient of ordinary
skill to be able to understand it. 5. Termination 5.1. The rights granted under this License will
terminate automatically if You fail to comply with any of its terms. However, if You become
compliant, then the rights granted under this License from a particular Contributor are reinstated
(a) provisionally, unless and until such Contributor explicitly and finally terminates Your grants,
and (b) on an ongoing basis, if such Contributor fails to notify You of the non-compliance by some
reasonable means prior to 60 days after You have come back into compliance. Moreover, Your grants
from a particular Contributor are reinstated on an ongoing basis if such Contributor notifies You of
the non-compliance by some reasonable means, this is the first time You have received notice of
non-compliance with this License from such Contributor, and You become compliant prior to 30 days
after Your receipt of the notice. 5.2. If You initiate litigation against any entity by asserting a
patent infringement claim (excluding declaratory judgment actions, counter-claims, and cross-claims)
alleging that a Contributor Version directly or indirectly infringes any patent, then the rights
granted to You by any and all Contributors for the Covered Software under Section 2.1 of this
License shall terminate. 5.3. In the event of termination under Sections 5.1 or 5.2 above, all end
user license agreements (excluding distributors and resellers) which have been validly granted by
You or Your distributors under this License prior to termination shall survive termination.
6. Disclaimer of Warranty Covered Software is provided under this License on an “as is” basis,
without warranty of any kind, either expressed, implied, or statutory, including, without
limitation, warranties that the Covered Software is free of defects, merchantable, fit for a
particular purpose or non-infringing. The entire risk as to the quality and performance of the
Covered Software is with You. Should any Covered Software prove defective in any respect, You (not
any Contributor) assume the cost of any necessary servicing, repair, or correction. This disclaimer
of warranty constitutes an essential part of this License. No use of any Covered Software is
authorized under this License except under this disclaimer.
7. Limitation of Liability Under no circumstances and under no legal theory, whether tort (including
negligence), contract, or otherwise, shall any Contributor, or anyone who distributes Covered
Software as permitted above, be liable to You for any direct, indirect, special, incidental, or
consequential damages of any character including, without limitation, damages for lost profits, loss
of goodwill, work stoppage, computer failure or malfunction, or any and all other commercial damages
or losses, even if such party shall have been informed of the possibility of such damages. This
limitation of liability shall not apply to liability for death or personal injury resulting from
such party’s negligence to the extent applicable law prohibits such limitation. Some jurisdictions
do not allow the exclusion or limitation of incidental or consequential damages, so this exclusion
and limitation may not apply to You. 8. Litigation Any litigation relating to this License may be
brought only in the courts of a jurisdiction where the defendant maintains its principal place of
business and such litigation shall be governed by laws of that jurisdiction, without reference to
its conflict-of-law provisions. Nothing in this Section shall prevent a party’s ability to bring
cross-claims or counter-claims. 9. Miscellaneous This License represents the complete agreement
concerning the subject matter hereof. If any provision of this License is held to be unenforceable,
such provision shall be reformed only to the extent necessary to make it enforceable. Any law or
regulation which provides that the language of a contract shall be construed against the drafter
shall not be used to construe this License against a Contributor. 10. Versions of the License 10.1.
New Versions Mozilla Foundation is the license steward. Except as provided in Section 10.3, no one
other than the license steward has the right to modify or publish new versions of this License. Each
version will be given a distinguishing version number. 10.2. Effect of New Versions You may
distribute the Covered Software under the terms of the version of the License under which You
originally received the Covered Software, or under the terms of any subsequent version published by
the license steward. 10.3. Modified Versions If you create software not governed by this License,
and you want to create a new license for such software, you may create and use a modified version of
this License if you rename the license and remove any references to the name of the license steward
(except to note that such modified license differs from this License). 10.4. Distributing Source
Code Form that is Incompatible With Secondary Licenses If You choose to distribute Source Code Form
that is Incompatible With Secondary Licenses under the terms of this version of the License, the
notice described in Exhibit B of this License must be attached. Exhibit A - Source Code Form License
Notice This Source Code Form is subject to the terms of the Mozilla Public License, v. 2.0. If a
copy of the MPL was not distributed with this file, You can obtain one at
https://mozilla.org/MPL/2.0/. If it is not possible or desirable to put the notice in a particular
file, then You may include the notice in a location (such as a LICENSE file in a relevant directory)
where a recipient would be likely to look for such a notice. You may add additional accurate notices
of copyright ownership. Exhibit B - “Incompatible With Secondary Licenses” Notice This Source Code
Form is “Incompatible With Secondary Licenses”, as defined by the Mozilla Public License, v. 2.0.
Filament
copyright owner]
Intel TBB
copyright owner]
Lib3mf
limf3mf is released under BSD and contains code from other third parties, mentioned below. BSD
license: Copyright (C) 2019 3MF Consortium All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted
provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this list of conditions
and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions
and the following disclaimer in the documentation and/or other materials provided with the
distribution. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY
EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE. libzip license: libzip is released under a 3-clause BSD license:
Copyright (C) 1999-2019 Dieter Baron and Thomas Klausner The authors can be contacted at
libzip@nih.at
provided that the following conditions are met: Redistributions of source code must retain the above
copyright notice, this list of conditions and the following disclaimer. Redistributions in binary
form must reproduce the above copyright notice, this list of conditions and the following disclaimer
in the documentation and/or other materials provided with the distribution. The names of the authors
may not be used to endorse or promote products derived from this software without specific prior
written permission. THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS’’ AND ANY EXPRESS OR IMPLIED
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
DAMAGE. zlib license: /* zlib.h -- interface of the 'zlib' general purpose compression library
version 1.2.11, January 15th, 2017 Copyright (C) 1995-2017 Jean-loup Gailly and Mark Adler This
software is provided 'as-is', without any express or implied warranty. In no event will the authors
be held liable for any damages arising from the use of this software. Permission is granted to
anyone to use this software for any purpose, including commercial applications, and to alter it and
redistribute it freely, subject to the following restrictions: 1. The origin of this software must
not be misrepresented; you must not claim that you wrote the original software. If you use this
software in a product, an acknowledgment in the product documentation would be appreciated but is
not required. 2. Altered source versions must be plainly marked as such, and must not be
misrepresented as being the original software. 3. This notice may not be removed or altered from any
source distribution. Jean-loup Gailly Mark Adler jloup@gzip.org madler@alumni.caltech.edu */
cpp-base64 license: Copyright © 2004-2017 by René Nyffenegger This source code is provided 'as-is',
without any express or implied warranty. In no event will the author be held liable for any damages
arising from the use of this software. Permission is granted to anyone to use this software for any
purpose, including commercial applications, and to alter it and redistribute it freely, subject to
the following restrictions: 1. The origin of this source code must not be misrepresented; you must
not claim that you wrote the original source code. If you use this source code in a product, an
acknowledgment in the product documentation would be appreciated but is not required. 2. Altered
source versions must be plainly marked as such, and must not be misrepresented as being the original
source code. 3. This notice may not be removed or altered from any source distribution. LibReSSL
license: /* ==================================================================== * Copyright (c)
1998-2011 The OpenSSL Project. All rights reserved. * *
Redistribution and use in source and binary forms, with or without * modification, are permitted
provided that the following conditions * are met: * *
1. Redistributions of source code must retain the above copyright * notice, this list of conditions
and the following disclaimer. * *
2. Redistributions in binary form must reproduce the above copyright * notice, this list of
conditions and the following disclaimer in * the documentation and/or other materials provided with
the * distribution. * * 3. All advertising materials mentioning features or use of this * software
must display the following acknowledgment: * "This product includes software developed by the
OpenSSL Project * for use in the OpenSSL Toolkit. (http://www.openssl.org/)" * * 4. The names
"OpenSSL Toolkit" and "OpenSSL Project" must not be used to * endorse or promote products derived
from this software without * prior written permission. For written permission, please contact *
openssl-core@openssl.org. * * 5. Products derived from this software may not be called "OpenSSL" *
nor may "OpenSSL" appear in their names without prior written * permission of the OpenSSL Project. *
6. Redistributions of any form whatsoever must retain the following * acknowledgment: * "This
product includes software developed by the OpenSSL Project * for use in the OpenSSL Toolkit
(http://www.openssl.org/)" * * THIS SOFTWARE IS PROVIDED BY THE OpenSSL PROJECT ``AS IS'' AND ANY *
EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE * IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE OpenSSL PROJECT OR * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT * NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, * STRICT
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) * ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED * OF THE POSSIBILITY OF SUCH DAMAGE. *
==================================================================== * * This product includes
cryptographic software written by Eric Young * (eay@cryptsoft.com). This product includes software
written by Tim * Hudson (tjh@cryptsoft.com). * */ Original SSLeay License ----------------------- /*
Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com) * All rights reserved. * * This package is an
SSL implementation written * by Eric Young (eay@cryptsoft.com). * The implementation was written so
as to conform with Netscapes SSL. * * This library is free for commercial and non-commercial use as
long as * the following conditions are aheared to. The following conditions * apply to all code
found in this distribution, be it the RC4, RSA, * lhash, DES, etc., code; not just the SSL code. The
SSL documentation * included with this distribution is covered by the same copyright terms * except
that the holder is Tim Hudson (tjh@cryptsoft.com). * * Copyright remains Eric Young's, and as such
any Copyright notices in * the code are not to be removed. * If this package is used in a product,
Eric Young should be given attribution * as the author of the parts of the library used. * This can
be in the form of a textual message at program startup or * in documentation (online or textual)
provided with the package. * *
1. Redistributions of source code must retain the copyright * notice, this list of conditions and
conditions and the following disclaimer in the * documentation and/or other materials provided with
the distribution. * 3. All advertising materials mentioning features or use of this software * must
display the following acknowledgement: * "This product includes cryptographic software written by *
Eric Young (eay@cryptsoft.com)" * The word 'cryptographic' can be left out if the rouines from the
library * being used are not cryptographic related :-). * 4. If you include any Windows specific
code (or a derivative thereof) from * the apps directory (application code) you must include an
acknowledgement: * "This product includes software written by Tim Hudson (tjh@cryptsoft.com)" * *
THIS SOFTWARE IS PROVIDED BY ERIC YOUNG ``AS IS'' AND * ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR PURPOSE * ARE DISCLAIMED.
IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE * FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE POSSIBILITY OF * SUCH DAMAGE. * * The licence and distribution terms for any publically
available version or * derivative of this code cannot be changed. i.e. this code cannot simply be *
copied and put under another distribution licence * [including the GNU Public Licence.] */
LLVM
============================================================================== The LLVM Project is
under the Apache License v2.0 with LLVM Exceptions:
copyright owner]
language governing permissions and limitations under the License. ---- LLVM Exceptions to the Apache
2.0 License ---- As an exception, if, as a result of your compiling your source code, portions of
this Software are embedded into an Object form of such source code, you may redistribute such
embedded portions in such Object form without complying with the conditions of Sections 4(a), 4(b)
and 4(d) of the License. In addition, if you combine or link compiled forms of this Software with
software that is licensed under the GPLv2 ("Combined Software") and if a court of competent
jurisdiction determines that the patent provision (Section 3), the indemnity provision (Section 9)
or other Section of the License conflicts with the conditions of the GPLv2, you may retroactively
and prospectively choose to deem waived or otherwise exclude such Section(s) of the License, but
only in their entirety and only with respect to the Combined Software.
============================================================================== Software from third
parties included in the LLVM Project:
contains third party software which is under different license terms. All such code will be
identified clearly using at least one of two mechanisms: 1) It will be in a separate directory tree
with its own `LICENSE.txt` or `LICENSE` file at the top containing the specific license and
restrictions which apply to that software, or 2) It will contain specific license and restriction
terms at the top of every file.
============================================================================== Legacy LLVM License
(https://llvm.org/docs/DeveloperPolicy.html#legacy):
============================================================================== University of
Illinois/NCSA Open Source License Copyright (c) 2003-2019 University of Illinois at
Urbana-Champaign. All rights reserved. Developed by: LLVM Team University of Illinois at
Urbana-Champaign http://llvm.org
associated documentation files (the "Software"), to deal with the Software without restriction,
furnished to do so, subject to the following conditions: * Redistributions of source code must
retain the above copyright notice, this list of conditions and the following disclaimers. *
and the following disclaimers in the documentation and/or other materials provided with the
distribution. * Neither the names of the LLVM Team, University of Illinois at Urbana-Champaign, nor
the names of its contributors may be used to endorse or promote products derived from this Software
without specific prior written permission.
NONINFRINGEMENT.
IN NO EVENT SHALL THE CONTRIBUTORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS WITH THE SOFTWARE.
Meshoptimizer
MIT License Copyright (c) 2016-2022 Arseny Kapoulkine
NONINFRINGEMENT.
MGSwipeTableCell
The
MIT License (MIT) Copyright (c) 2018 Imanol Fernandez @MortimerGoro
NONINFRINGEMENT.
MikkTSpace
Copyright (C) 2011 by Morten S. Mikkelsen * * This software is provided 'as-is', without any express
or implied * warranty. In no event will the authors be held liable for any damages * arising from
the use of this software. * * Permission is granted to anyone to use this software for any purpose,
* including commercial applications, and to alter it and redistribute it * freely, subject to the
following restrictions: * * 1. The origin of this software must not be misrepresented; you must not
* claim that you wrote the original software. If you use this software * in a product, an
acknowledgment in the product documentation would be * appreciated but is not required. * 2. Altered
source versions must be plainly marked as such, and must not be * misrepresented as being the
original software. * 3. This notice may not be removed or altered from any source distribution.
Miniz
Copyright 2013-2014 RAD Game Tools and Valve Software Copyright 2010-2014 Rich Geldreich and
Tenacious Software LLC All Rights Reserved.
NONINFRINGEMENT.
MKStoreKit
MKStoreKit is licensed under
MIT License
NONINFRINGEMENT.
moodycamel::ConcurrentQueue
This license file applies to everything in this repository except that which is explicitly annotated
as being written by other authors, i.e. the Boost queue (included in the benchmarks for comparison),
Intel's TBB library (ditto), dlib::pipe (ditto), the CDSChecker tool (used for verification), the
Relacy model checker (ditto), and Jeff Preshing's semaphore implementation (used in the blocking
queue) which has a zlib license (embedded in lightweightsempahore.h). --- Simplified BSD License:
Copyright (c) 2013-2016, Cameron Desrochers. All rights reserved.
provided that the following conditions are met: - Redistributions of source code must retain the
above copyright notice, this list of conditions and the following disclaimer. - Redistributions in
binary form must reproduce the above copyright notice, this list of conditions and the following
disclaimer in the documentation and/or other materials provided with the distribution. THIS SOFTWARE
IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
POSSIBILITY OF SUCH DAMAGE. --- I have also chosen to dual-license under the Boost Software License
as an alternative to the Simplified BSD license above: Boost Software License - Version 1.0 - August
17th, 2003
Permission is hereby granted, free of charge, to any person or organization obtaining a copy of the
software and accompanying documentation covered by this license (the "Software") to use, reproduce,
display, distribute, execute, and transmit the Software, and to prepare derivative works of the
Software, and to permit third-parties to whom the Software is furnished to do so, all subject to the
following: The copyright notices in the Software and this entire statement, including the above
license grant, this restriction and the following disclaimer, must be included in all copies of the
Software, in whole or in part, and all derivative works of the Software, unless such copies or
derivative works are solely in the form of machine-executable object code generated by a source
language processor.
NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND
NON-INFRINGEMENT.
IN NO EVENT SHALL THE COPYRIGHT HOLDERS OR ANYONE DISTRIBUTING THE SOFTWARE BE LIABLE FOR ANY
DAMAGES OR OTHER LIABILITY, WHETHER IN CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
moodycamel::ReaderWriterQueue
This license applies to all the code in this repository except that written by third parties, namely
the files in benchmarks/ext, which have their own licenses, and Jeff Preshing's semaphore
implementation (used in the blocking queues) which has a zlib license (embedded in atomicops.h).
Simplified BSD License: Copyright (c) 2013-2021, Cameron Desrochers All rights reserved.
mpack
The
MIT License (MIT) Copyright (c) 2015-2021 Nicholas Fraser and the MPack authors
NONINFRINGEMENT.
pinyin (Kaifangcidian)
Traditional-to-Simplified Chinese character table (trans_word.txt in cpp-pinyin), derived from:
pinyin (漢語拼音轉換表) - https://github.com/kfcd/pinyin
© 2015 開放詞典 (Kaifangcidian) - http://www.kaifangcidian.com
Licensed under the Creative Commons Attribution 3.0 Unported License (CC BY 3.0).
https://creativecommons.org/licenses/by/3.0/
The table was converted to a different file format by the cpp-pinyin project (https://github.com/wolfgitpr/cpp-pinyin). Shapr3D uses it unmodified.
pugixml
MIT License Copyright (c) 2006-2024 Arseny Kapoulkine
NONINFRINGEMENT.
Python
Copyright (c) 2001 Python Software Foundation; All Rights Reserved PYTHON SOFTWARE FOUNDATION
LICENSE VERSION 2 -------------------------------------------- 1. This LICENSE AGREEMENT is between
the Python Software Foundation ("PSF"), and the Individual or Organization ("Licensee") accessing
and otherwise using this software ("Python") in source or binary form and its associated
documentation. 2. Subject to the terms and conditions of this License Agreement, PSF hereby grants
Licensee a nonexclusive, royalty-free, world-wide license to reproduce, analyze, test, perform
and/or display publicly, prepare derivative works, distribute, and otherwise use Python alone or in
any derivative version, provided, however, that PSF's License Agreement and PSF's notice of
copyright, i.e., "Copyright (c) 2001 Python Software Foundation; All Rights Reserved" are retained
in Python alone or in any derivative version prepared by Licensee. 3. In the event Licensee prepares
a derivative work that is based on or incorporates Python or any part thereof, and wants to make the
derivative work available to others as provided herein, then Licensee hereby agrees to include in
any such work a brief summary of the changes made to Python. 4. PSF is making Python available to
Licensee on an "AS IS" basis. PSF MAKES NO REPRESENTATIONS OR WARRANTIES, EXPRESS OR IMPLIED. BY WAY
OF EXAMPLE, BUT NOT LIMITATION, PSF MAKES NO AND DISCLAIMS ANY REPRESENTATION OR WARRANTY OF
MERCHANTABILITY OR FITNESS FOR ANY PARTICULAR PURPOSE OR THAT THE USE OF PYTHON WILL NOT INFRINGE
ANY THIRD PARTY RIGHTS. 5. PSF SHALL NOT BE LIABLE TO LICENSEE OR ANY OTHER USERS OF PYTHON FOR ANY
INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OR LOSS AS A RESULT OF MODIFYING, DISTRIBUTING, OR
OTHERWISE USING PYTHON, OR ANY DERIVATIVE THEREOF, EVEN IF ADVISED OF THE POSSIBILITY THEREOF. 6.
This License Agreement will automatically terminate upon a material breach of its terms and
conditions.
7. Nothing in this License Agreement shall be deemed to create any relationship of agency,
partnership, or joint venture between PSF and Licensee. This License Agreement does not grant
permission to use PSF trademarks or trade name in a trademark sense to endorse or promote products
or services of Licensee, or any third party. 8. By copying, installing or otherwise using Python,
Licensee agrees to be bound by the terms and conditions of this License Agreement.
RapidJSON
Tencent is pleased to support the open source community by making RapidJSON available. Copyright (C)
2015 THL A29 Limited, a Tencent company, and Milo Yip.
Licensed under the
MIT License (the "License"); you may not use this file except in compliance with the License. You
may obtain a copy of the License at http://opensource.org/licenses/MIT Unless required by applicable
law or agreed to in writing, software distributed under the License is distributed on an "AS IS"
BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for
the specific language governing permissions and limitations under the License.
Reachability
Copyright (c) 2011-2013, Tony Million. All rights reserved.
Sentry
Apache License, Version 2.0 (Apache-2.0) Sentry’s default license of choice is the permissive but
protective Apache-2.0 license. This license is OSI-approved, widely adopted, and still has some
safe-guards like attribution requirement or patents protection. Any new projects are licensed under
Apache-2.0 unless there’s a concern around GPL-2.0 compatibility for adoption.
The
MIT License (MIT) We use the MIT license as a fallback for the Apache-2.0 license where we need to
reach to a wider audience, due to the GPL-2.0 incompatibility. This is the license we use for all
our SDKs. Functional Source License, Version 1.1, Apache 2.0 Change License (FSL-1.1-Apache-2.0) All
components powering the main Sentry and Codecov web apps use FSL, which limits their usage in a
commercial Sentry-like offering. If you have questions, please reach out to us at oss@sentry.io.
spdlog
The
MIT License (MIT) Copyright (c) 2016 Gabi Melman.
NONINFRINGEMENT.
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. -- NOTE: Third party
dependency used by this software -- This software depends on the fmt lib (MIT License), and users
must comply to its license: https://raw.githubusercontent.com/fmtlib/fmt/master/LICENSE
SQLite
License: SQLite
stb_image
This software is available under 2 licenses -- choose whichever you prefer.
------------------------------------------------------------------------------ ALTERNATIVE A -
MIT License Copyright (c) 2017 Sean Barrett
NONINFRINGEMENT.
------------------------------------------------------------------------------ ALTERNATIVE B -
Public Domain (www.unlicense.org) This is free and unencumbered software released into the public
domain. Anyone is free to copy, modify, publish, use, compile, sell, or distribute this software,
either in source code form or as a compiled binary, for any purpose, commercial or non-commercial,
and by any means. In jurisdictions that recognize copyright laws, the author or authors of this
software dedicate any and all copyright interest in the software to the public domain. We make this
NONINFRINGEMENT.
tinyobjloader
The
MIT License (MIT) Copyright (c) 2012-2019 Syoyo Fujita and many contributors.
NONINFRINGEMENT.
TL::expected
Creative Commons Legal Code CC0 1.0 Universal CREATIVE COMMONS CORPORATION IS NOT A LAW FIRM AND
DOES NOT PROVIDE LEGAL SERVICES. DISTRIBUTION OF THIS DOCUMENT DOES NOT CREATE AN ATTORNEY-CLIENT
RELATIONSHIP. CREATIVE COMMONS PROVIDES THIS INFORMATION ON AN "AS-IS" BASIS. CREATIVE COMMONS MAKES
NO WARRANTIES REGARDING THE USE OF THIS DOCUMENT OR THE INFORMATION OR WORKS PROVIDED HEREUNDER, AND
DISCLAIMS LIABILITY FOR DAMAGES RESULTING FROM THE USE OF THIS DOCUMENT OR THE INFORMATION OR WORKS
PROVIDED HEREUNDER. Statement of Purpose The laws of most jurisdictions throughout the world
automatically confer exclusive Copyright and Related Rights (defined below) upon the creator and
subsequent owner(s) (each and all, an "owner") of an original work of authorship and/or a database
(each, a "Work"). Certain owners wish to permanently relinquish those rights to a Work for the
purpose of contributing to a commons of creative, cultural and scientific works ("Commons") that the
public can reliably and without fear of later claims of infringement build upon, modify, incorporate
in other works, reuse and redistribute as freely as possible in any form whatsoever and for any
purposes, including without limitation commercial purposes. These owners may contribute to the
Commons to promote the ideal of a free culture and the further production of creative, cultural and
scientific works, or to gain reputation or greater distribution for their Work in part through the
use and efforts of others. For these and/or other purposes and motivations, and without any
expectation of additional consideration or compensation, the person associating CC0 with a Work (the
"Affirmer"), to the extent that he or she is an owner of Copyright and Related Rights in the Work,
voluntarily elects to apply CC0 to the Work and publicly distribute the Work under its terms, with
knowledge of his or her Copyright and Related Rights in the Work and the meaning and intended legal
effect of CC0 on those rights.
1. Copyright and Related Rights. A Work made available under CC0 may be protected by copyright and
related or neighboring rights ("Copyright and Related Rights"). Copyright and Related Rights
include, but are not limited to, the following: i. the right to reproduce, adapt, distribute,
perform, display, communicate, and translate a Work; ii. moral rights retained by the original
author(s) and/or performer(s); iii. publicity and privacy rights pertaining to a person's image or
likeness depicted in a Work; iv. rights protecting against unfair competition in regards to a Work,
subject to the limitations in paragraph 4(a), below; v. rights protecting the extraction,
dissemination, use and reuse of data in a Work; vi. database rights (such as those arising under
Directive 96/9/EC of the European Parliament and of the Council of 11 March 1996 on the legal
protection of databases, and under any national implementation thereof, including any amended or
successor version of such directive); and vii. other similar, equivalent or corresponding rights
throughout the world based on applicable law or treaty, and any national implementations thereof. 2.
Waiver. To the greatest extent permitted by, but not in contravention of, applicable law, Affirmer
hereby overtly, fully, permanently, irrevocably and unconditionally waives, abandons, and surrenders
all of Affirmer's Copyright and Related Rights and associated claims and causes of action, whether
now known or unknown (including existing as well as future claims and causes of action), in the Work
(i) in all territories worldwide, (ii) for the maximum duration provided by applicable law or treaty
(including future time extensions), (iii) in any current or future medium and for any number of
copies, and (iv) for any purpose whatsoever, including without limitation commercial, advertising or
promotional purposes (the "Waiver"). Affirmer makes the Waiver for the benefit of each member of the
public at large and to the detriment of Affirmer's heirs and successors, fully intending that such
Waiver shall not be subject to revocation, rescission, cancellation, termination, or any other legal
or equitable action to disrupt the quiet enjoyment of the Work by the public as contemplated by
Affirmer's express Statement of Purpose. 3. Public License Fallback. Should any part of the Waiver
for any reason be judged legally invalid or ineffective under applicable law, then the Waiver shall
be preserved to the maximum extent permitted taking into account Affirmer's express Statement of
Purpose. In addition, to the extent the Waiver is so judged Affirmer hereby grants to each affected
person a royalty-free, non transferable, non sublicensable, non exclusive, irrevocable and
unconditional license to exercise Affirmer's Copyright and Related Rights in the Work (i) in all
territories worldwide, (ii) for the maximum duration provided by applicable law or treaty (including
future time extensions), (iii) in any current or future medium and for any number of copies, and
(iv) for any purpose whatsoever, including without limitation commercial, advertising or promotional
purposes (the "License"). The License shall be deemed effective as of the date CC0 was applied by
Affirmer to the Work. Should any part of the License for any reason be judged legally invalid or
ineffective under applicable law, such partial invalidity or ineffectiveness shall not invalidate
the remainder of the License, and in such case Affirmer hereby affirms that he or she will not (i)
exercise any of his or her remaining Copyright and Related Rights in the Work or (ii) assert any
associated claims and causes of action with respect to the Work, in either case contrary to
4. Limitations and Disclaimers. a. No trademark or patent rights held by Affirmer are waived,
abandoned, surrendered, licensed or otherwise affected by this document. b. Affirmer offers the Work
as-is and makes no representations or warranties of any kind concerning the Work, express, implied,
statutory or otherwise, including without limitation warranties of title, merchantability, fitness
for a particular purpose, non infringement, or the absence of latent or other defects, accuracy, or
the present or absence of errors, whether or not discoverable, all to the greatest extent
permissible under applicable law. c. Affirmer disclaims responsibility for clearing rights of other
persons that may apply to the Work or any use thereof, including without limitation any person's
Copyright and Related Rights in the Work. Further, Affirmer disclaims responsibility for obtaining
any necessary consents, permissions or other rights required for any use of the Work. d. Affirmer
understands and acknowledges that Creative Commons is not a party to this document and has no duty
or obligation with respect to this CC0 or use of the Work.
tree-sitter
The
MIT License (MIT) Copyright (c) 2018-2024 Max Brunsfeld
NONINFRINGEMENT.
USD
Modified Apache 2.0 License
TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
1. Definitions. "License" shall mean the terms and conditions for use, reproduction, and
distribution as defined by Sections 1 through 9 of this document. "Licensor" shall mean the
copyright owner or entity authorized by the copyright owner that is granting the License. "Legal
Entity" shall mean the union of the acting entity and all other entities that control, are
controlled by, or are under common control with that entity. For the purposes of this definition,
"control" means (i) the power, direct or indirect, to cause the direction or management of such
entity, whether by contract or otherwise, or (ii) ownership of fifty percent (50%) or more of the
outstanding shares, or (iii) beneficial ownership of such entity. "You" (or "Your") shall mean an
individual or Legal Entity exercising permissions granted by this License. "Source" form shall mean
the preferred form for making modifications, including but not limited to software source code,
documentation source, and configuration files. "Object" form shall mean any form resulting from
mechanical transformation or translation of a Source form, including but not limited to compiled
object code, generated documentation, and conversions to other media types. "Work" shall mean the
work of authorship, whether in Source or Object form, made available under the License, as indicated
by a copyright notice that is included in or attached to the work (an example is provided in the
Appendix below). "Derivative Works" shall mean any work, whether in Source or Object form, that is
based on (or derived from) the Work and for which the editorial revisions, annotations,
elaborations, or other modifications represent, as a whole, an original work of authorship. For the
purposes of this License, Derivative Works shall not include works that remain separable from, or
merely link (or bind by name) to the interfaces of, the Work and Derivative Works thereof.
"Contribution" shall mean any work of authorship, including the original version of the Work and any
modifications or additions to that Work or Derivative Works thereof, that is intentionally submitted
to Licensor for inclusion in the Work by the copyright owner or by an individual or Legal Entity
authorized to submit on behalf of the copyright owner. For the purposes of this definition,
"submitted" means any form of electronic, verbal, or written communication sent to the Licensor or
its representatives, including but not limited to communication on electronic mailing lists, source
code control systems, and issue tracking systems that are managed by, or on behalf of, the Licensor
for the purpose of discussing and improving the Work, but excluding communication that is
conspicuously marked or otherwise designated in writing by the copyright owner as "Not a
Contribution." "Contributor" shall mean Licensor and any individual or Legal Entity on behalf of
whom a Contribution has been received by Licensor and subsequently incorporated within the Work.
2. Grant of Copyright License. Subject to the terms and conditions of this License, each Contributor
hereby grants to You a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable
copyright license to reproduce, prepare Derivative Works of, publicly display, publicly perform,
sublicense, and distribute the Work and such Derivative Works in Source or Object form.
3. Grant of Patent License. Subject to the terms and conditions of this License, each Contributor
(except as stated in this section) patent license to make, have made, use, offer to sell, sell,
import, and otherwise transfer the Work, where such license applies only to those patent claims
licensable by such Contributor that are necessarily infringed by their Contribution(s) alone or by
combination of their Contribution(s) with the Work to which such Contribution(s) was submitted. If
You institute patent litigation against any entity (including a cross-claim or counterclaim in a
lawsuit) alleging that the Work or a Contribution incorporated within the Work constitutes direct or
contributory patent infringement, then any patent licenses granted to You under this License for
that Work shall terminate as of the date such litigation is filed.
4. Redistribution. You may reproduce and distribute copies of the Work or Derivative Works thereof
in any medium, with or without modifications, and in Source or Object form, provided that You meet
the following conditions: (a) You must give any other recipients of the Work or Derivative Works a
copy of this License; and (b) You must cause any modified files to carry prominent notices stating
that You changed the files; and (c) You must retain, in the Source form of any Derivative Works that
You distribute, all copyright, patent, trademark, and attribution notices from the Source form of
the Work, excluding those notices that do not pertain to any part of the Derivative Works; and (d)
If the Work includes a "NOTICE" text file as part of its distribution, then any Derivative Works
that You distribute must include a readable copy of the attribution notices contained within such
NOTICE file, excluding those notices that do not pertain to any part of the Derivative Works, in at
least one of the following places: within a NOTICE text file distributed as part of the Derivative
Works; within the Source form or documentation, if provided along with the Derivative Works; or,
within a display generated by the Derivative Works, if and wherever such third-party notices
normally appear. The contents of the NOTICE file are for informational purposes only and do not
modify the License. You may add Your own attribution notices within Derivative Works that You
distribute, alongside or as an addendum to the NOTICE text from the Work, provided that such
additional attribution notices cannot be construed as modifying the License. You may add Your own
copyright statement to Your modifications and may provide additional or different license terms and
conditions for use, reproduction, or distribution of Your modifications, or for any such Derivative
Works as a whole, provided Your use, reproduction, and distribution of the Work otherwise complies
with the conditions stated in this License.
5. Submission of Contributions. Unless You explicitly state otherwise, any Contribution
intentionally submitted for inclusion in the Work by You to the Licensor shall be under the terms
and conditions of this License, without any additional terms or conditions. Notwithstanding the
above, nothing herein shall supersede or modify the terms of any separate license agreement you may
have executed with Licensor regarding such Contributions.
6. Trademarks. This License does not grant permission to use the trade names, trademarks, service
marks, or product names of the Licensor and its affiliates, except as required to comply with
Section 4(c) of the License and to reproduce the content of the NOTICE file.
7. Disclaimer of Warranty. Unless required by applicable law or agreed to in writing, Licensor
provides the Work (and each Contributor provides its Contributions) on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied, including, without limitation, any
warranties or conditions of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A PARTICULAR
PURPOSE. You are solely responsible for determining the appropriateness of using or redistributing
the Work and assume any risks associated with Your exercise of permissions under this License.
8. Limitation of Liability. In no event and under no legal theory, whether in tort (including
negligence), contract, or otherwise, unless required by applicable law (such as deliberate and
grossly negligent acts) or agreed to in writing, shall any Contributor be liable to You for damages,
including any direct, indirect, special, incidental, or consequential damages of any character
arising as a result of this License or out of the use or inability to use the Work (including but
not limited to damages for loss of goodwill, work stoppage, computer failure or malfunction, or any
and all other commercial damages or losses), even if such Contributor has been advised of the
9. Accepting Warranty or Additional Liability. While redistributing the Work or Derivative Works
thereof, You may choose to offer, and charge a fee for, acceptance of support, warranty, indemnity,
or other liability obligations and/or rights consistent with this License. However, in accepting
such obligations, You may act only on Your own behalf and on Your sole responsibility, not on behalf
of any other Contributor, and only if You agree to indemnify, defend, and hold each Contributor
harmless for any liability incurred by, or claims asserted against, such Contributor by reason of
============================================================ RapidJSON
============================================================ Tencent is pleased to support the open
source community by making RapidJSON available. Copyright (C) 2015 THL A29 Limited, a Tencent
company, and Milo Yip. All rights reserved. If you have downloaded a copy of the RapidJSON binary
from Tencent, please note that the RapidJSON binary is licensed under the
MIT License. If you have downloaded a copy of the RapidJSON source code from Tencent, please note
that RapidJSON source code is licensed under the
MIT License, except for the third-party components listed below which are subject to different
license terms. Your integration of RapidJSON into your own projects may require compliance with the
MIT License, as well as the other licenses applicable to the third-party components included within
RapidJSON. To avoid the problematic JSON license in your own projects, it's sufficient to exclude
the bin/jsonchecker/ directory, as it's the only code under the JSON license. A copy of the
MIT License is included in this file. Other dependencies and licenses: Open Source Software Licensed
Under the BSD License: -------------------------------------------------------------------- The
msinttypes r29 Copyright (c) 2006-2013 Alexander Chemeris All rights reserved.
provided that the following conditions are met: * Redistributions of source code must retain the
above copyright notice, this list of conditions and the following disclaimer. * Redistributions in
disclaimer in the documentation and/or other materials provided with the distribution. * Neither the
name of copyright holder nor the names of its contributors may be used to endorse or promote
products derived from this software without specific prior written permission. THIS SOFTWARE IS
PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED.
IN NO EVENT SHALL THE REGENTS AND CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
POSSIBILITY OF SUCH DAMAGE. Open Source Software Licensed Under the JSON License:
-------------------------------------------------------------------- json.org Copyright (c) 2002
JSON.org All Rights Reserved. JSON_checker Copyright (c) 2002 JSON.org All Rights Reserved. Terms of
the JSON License: ---------------------------------------------------
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and
associated documentation files (the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute,
sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions: The above copyright notice and this
permission notice shall be included in all copies or substantial portions of the Software. The
Software shall be used for Good, not Evil.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT
NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. Terms of the
MIT License: --------------------------------------------------------------------
NONINFRINGEMENT.
============================================================ pygilstate_check
The
MIT License (MIT) Copyright (c) 2014, Pankaj Pandey
NONINFRINGEMENT.
============================================================ double-conversion
============================================================ Copyright 2006-2011, the V8 project
authors. All rights reserved.
name of Google Inc. nor the names of its contributors may be used to endorse or promote products
derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY
THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT
NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
POSSIBILITY OF SUCH DAMAGE. ============================================================
OpenEXR/IlmBase/Half ============================================================
/////////////////////////////////////////////////////////////////////////// // // Copyright (c)
2002, Industrial Light & Magic, a division of Lucas // Digital Ltd. LLC // // All rights reserved.
Redistribution and use in source and binary forms, with or without // modification, are permitted
provided that the following conditions are // met: // * Redistributions of source code must retain
the above copyright // notice, this list of conditions and the following disclaimer. // *
Redistributions in binary form must reproduce the above // copyright notice, this list of conditions
and the following disclaimer // in the documentation and/or other materials provided with the //
distribution. // * Neither the name of Industrial Light & Magic nor the names of // its contributors
may be used to endorse or promote products derived // from this software without specific prior
written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS
IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES
OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF
THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. //
============================================================ Apple Technical Q&A QA1361 - Detecting
the Debugger https://developer.apple.com/library/content/qa/qa1361/_index.html
============================================================ Sample code project: Detecting the
Debugger Version: 1.0 Abstract: Shows how to determine if code is being run under the debugger.
IMPORTANT: This Apple software is supplied to you by Apple Inc. ("Apple") in consideration of your
agreement to the following terms, and your use, installation, modification or redistribution of this
Apple software constitutes acceptance of these terms. If you do not agree with these terms, please
do not use, install, modify or redistribute this Apple software. In consideration of your agreement
to abide by the following terms, and subject to these terms, Apple grants you a personal,
non-exclusive license, under Apple's copyrights in this original Apple software (the "Apple
Software"), to use, reproduce, modify and redistribute the Apple Software, with or without
modifications, in source and/or binary forms; provided that if you redistribute the Apple Software
in its entirety and without modifications, you must retain this notice and the following text and
disclaimers in all such redistributions of the Apple Software. Neither the name, trademarks, service
marks or logos of Apple Inc. may be used to endorse or promote products derived from the Apple
Software without specific prior written permission from Apple. Except as expressly stated in this
notice, no other rights or licenses, express or implied, are granted by Apple herein, including but
not limited to any patent rights that may be infringed by your derivative works or by other works in
which the Apple Software may be incorporated. The Apple Software is provided by Apple on an "AS IS"
basis. APPLE MAKES NO WARRANTIES, EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION THE IMPLIED
WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, REGARDING THE
APPLE SOFTWARE OR ITS USE AND OPERATION ALONE OR IN COMBINATION WITH YOUR PRODUCTS.
IN NO EVENT SHALL APPLE BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) ARISING IN ANY WAY OUT OF THE USE, REPRODUCTION, MODIFICATION
AND/OR DISTRIBUTION OF THE APPLE SOFTWARE, HOWEVER CAUSED AND WHETHER UNDER THEORY OF CONTRACT, TORT
(INCLUDING NEGLIGENCE), STRICT LIABILITY OR OTHERWISE, EVEN IF APPLE HAS BEEN ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE. ============================================================ LZ4
============================================================ LZ4 - Fast LZ compression algorithm
Copyright (C) 2011-present, Yann Collet. BSD 2-Clause License
(http://www.opensource.org/licenses/bsd-license.php)
POSSIBILITY OF SUCH DAMAGE. You can contact the author at : - LZ4 homepage : http://www.lz4.org -
LZ4 source repository : https://github.com/lz4/lz4
============================================================ stb
============================================================ stb_image - v2.19 - public domain image
loader - http://nothings.org/stb no warranty implied; use at your own risk stb_image_resize - v0.95
- public domain image resizing by Jorge L Rodriguez (@VinoBS) - 2014 http://github.com/nothings/stb
stb_image_write - v1.09 - public domain - http://nothings.org/stb/stb_image_write.h writes out
PNG/BMP/TGA/JPEG/HDR images to C stdio - Sean Barrett 2010-2015 no warranty implied; use at your own
risk ALTERNATIVE B - Public Domain (www.unlicense.org) This is free and unencumbered software
released into the public domain. Anyone is free to copy, modify, publish, use, compile, sell, or
distribute this software, either in source code form or as a compiled binary, for any purpose,
commercial or non-commercial, and by any means. In jurisdictions that recognize copyright laws, the
author or authors of this software dedicate any and all copyright interest in the software to the
public domain. We make this dedication for the benefit of the public at large and to the detriment
of our heirs and successors. We intend this dedication to be an overt act of relinquishment in
perpetuity of all present and future rights to this software under copyright law.
NONINFRINGEMENT.
IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR
============================================================ pugixml
MIT License Copyright (c) 2006-2019 Arseny Kapoulkine
NONINFRINGEMENT.
============================================================ Vulkan C++ examples and demos (dome
light texture filtering) ============================================================
The
MIT License (MIT) Copyright (c) 2016 Sascha Willems
NONINFRINGEMENT.
============================================================ pbrt (Hammersley Low-Discrepancy
Sampling Sequence) ============================================================ Copyright (c)
1998-2015, Matt Pharr, Greg Humphreys, and Wenzel Jakob. All rights reserved.
in the documentation and/or other materials provided with the distribution. THIS SOFTWARE IS
POSSIBILITY OF SUCH DAMAGE. ============================================================ Draco
============================================================ USD bundles Draco, which is available
under the Apache 2.0 license. For details, see
https://github.com/google/draco/blob/master/README.md.
============================================================ Roboto Fonts
============================================================ USD bundles Roboto fonts, which is
available under the Apache 2.0 license. For details, see
https://fonts.google.com/specimen/Roboto#license
============================================================ Roboto Mono Fonts
============================================================ USD bundles Roboto Mono fonts, which is
https://fonts.google.com/specimen/Roboto+Mono#license
============================================================ Vulkan Memory Allocator
============================================================ Copyright (c) 2017-2020 Advanced Micro
Devices, Inc. All rights reserved.
NONINFRINGEMENT.
============================================================ Spirv Reflect
============================================================ Copyright 2017-2018 Google Inc.
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in
compliance with the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0 Unless required by applicable law or agreed to in
writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific
============================================================ khrplatform.h
============================================================ Copyright (c) 2008-2018 The Khronos
Group Inc.
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and/or
associated documentation files (the "Materials"), to deal in the Materials without restriction,
sublicense, and/or sell copies of the Materials, and to permit persons to whom the Materials are
permission notice shall be included in all copies or substantial portions of the Materials. THE
MATERIALS ARE PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
CONNECTION WITH THE MATERIALS OR THE USE OR OTHER DEALINGS IN THE MATERIALS.
============================================================ surfgrad-bump-standalone-demo
MIT License Copyright (c) 2020 mmikk
NONINFRINGEMENT.
================================================================ Tessil robin-map
MIT License Copyright (c) 2017 Thibaut Goetghebuer-Planchon <tessil@gmx.com>
NONINFRINGEMENT.
Welder
Windows Community Toolkit
Copyright © .NET Foundation and Contributors All rights reserved.
Licensed under the
MIT License:
THE SOFTWARE IS PROVIDED AS IS, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
Xatlas
MIT License Copyright (c) 2018-2020 Jonathan Young
NONINFRINGEMENT.
xxHash
xxHash Library Copyright (c) 2012-2021 Yann Collet All rights reserved. BSD 2-Clause License
(https://www.opensource.org/licenses/bsd-license.php)
zh_CN
MIT License
Copyright (c) 2018 hustwang
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
The above copyright notice and this permission notice shall be included in all
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.Zstandard
BSD License
For Zstandard software
Copyright (c) Meta Platforms, Inc. and affiliates. All rights reserved.
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this
* Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
* Neither the name Facebook, nor Meta, nor the names of its contributors may
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
