Shapr3D Cloud is a set of cloud-based features that are automatically enabled when you sign up for Shapr3D. With Shapr3D Cloud, you can use features like Sync to make your project available on all your devices, and also provide backup by securely uploading your projects to the cloud.
Using Shapr3D Cloud doesn’t mean that you can only access your projects while online. By default, all projects that you create on your device still exist locally and are exclusively tied to your account, allowing you to use Shapr3D and access your projects offline.
Note: If you're using Shapr3D Free, you can only export your projects to low-resolution STL and low-resolution 3MF. To learn more visit Shapr3D subscription plans.
Shapr3D Cloud offers the following features:
